I've been trying to capture line 21 closed caption (EIA-608) data from an analog Laserdisc source. I'd like it to end up in something like an SRT file. I've spent several hours trying to make this work somehow. I'm using an old bt878 based card (Hauppauge) for this because they're well-supported and versatile.
I've tried zvbi-ntsc-cc in Linux, which never decodes anything.
I've also tried following these old instructions for Graphedit, which looked promising, but apparently requires a special doom9 version of Graphedit which includes a "dump" filter. I can't find that anywhere, it seems to be gone now. http://www.theneitherworld.com/mcpoodle/SCC_TOOLS/DOCS/SCC_TOOLS.HTML#capture_analog
I've even tried using the bt8x8 tweaker in VirtualDub to see if I can capture the VBI lines directly into the image. I can, but there doesn't seem to be any tool that can do anything useful with that.
So, this is starting to drive me nuts now. Does anybody have any idea how I can get this accomplished? Thanks!
Is this it?
https://forum.doom9.org/showthread.php?t=166933Last edited by lordsmurf; 16th Jan 2021 at 01:56.
If you want to try GraphStudioNext instead of GraphEdit, it seems to have a dump filter that can be accessed via the pop-up menu that appears when the user selects Graph->Insert Filter.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks to both of you, these both seem to be viable solutions. I'll give it another try.
I just bought a PAL VHS with encoded closed captions on top of the video (white lines). Can I extract them with GraphStudioNext, or am I missing something?
Thanks in advance!
Remove closed caption from mkv
By arktay in forum SubtitleReplies: 25Last Post: 16th May 2023, 13:18 -
Capturing analog video recorded onto 8mm Data Tapes (Data8)
By infjmm03 in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2020, 20:35 -
Closed Caption Downloader
By farafero21 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jun 2020, 06:20 -
TBS closed caption!
By Derel in forum Video Streaming DownloadingReplies: 3Last Post: 18th Feb 2019, 13:42 -
Would like closed caption expert to answer a few questions
By jimdagys in forum SubtitleReplies: 4Last Post: 16th Jul 2016, 21:38
