Hello, this is my first time making a DVD I'm trying to make the Video_TS file for it and so I clicked "just generate". and it gave me this:
Windows 10 (build 19041), 64-bit edition
FFmpeg: libavformat 58.20.100, libavcodec 58.35.100, libavutil 56.22.100
Prepare
Cleaning temporary directory
Search for transcoded files in cache
| Input size | Output duration | Bitrate | Estimated output size
VMGM menu 1 | | | 8.0 Mb/s | 0.1 MB
mp3 | 2.9 MB | | 192 Kb/s | 3.3 MB
VMGM menu 2 | | | 8.0 Mb/s | 0.1 MB
VMGM menu 3 | | | 8.0 Mb/s | 0.1 MB
Menu 1 | | | 8.0 Mb/s | 0.1 MB
Title 1
avi | 199.5 MB | 26:01.319 sec | 2.4 Mb/s | 499.3 MB
Title 2
avi | 200.0 MB | 26:34.039 sec | 2.4 Mb/s | 509.8 MB
Title 3
avi | 200.1 MB | 22:20.400 sec | 2.4 Mb/s | 428.7 MB
Title 4
avi | 200.1 MB | 24:48.319 sec | 2.4 Mb/s | 476.0 MB
Title 5
avi | 199.9 MB | 23:24.528 sec | 2.4 Mb/s | 449.2 MB
Title 6
avi | 199.9 MB | 25:37.488 sec | 2.4 Mb/s | 491.7 MB
Title 7
avi | 199.5 MB | 25:01.847 sec | 2.4 Mb/s | 480.3 MB
Title 8
avi | 19.3 MB | 2:19.800 sec | 2.4 Mb/s | 44.7 MB
Title 9
avi | 79.3 MB | 9:33.168 sec | 2.4 Mb/s | 183.3 MB
Title 10
avi | 379.0 MB | 46:54.168 sec | 2.4 Mb/s | 900.0 MB
Total | | 3:52:35.079 sec | | 4476.6 MB
Generating menu 1 of 4
Create menu MPEG
Audio duration: 139.128163 sec
Frame count of menu: 3478
Multiplexing audio and video
Transcode video file: D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.m2v
Need encode: true, use mplex: true
Executing command: ffmpeg-vbr.bat -threads 4 -i "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.m2v" -i "D:\pictures\Doctor Who\Doctor Who (1963) - Original Theme music video.mp3" -f mpeg2video -c:v:0 copy -bufsize:v:0 1835008 -map 0:v:0 "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg.m2v" -f ac3 -b:a 192000 -ar 48000 -c:a:0 ac3 -map 1:a:0 "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg.audio0"
'F_DRIVE' is not recognized as an internal or external command,
operable program or batch file.
'F_PATH' is not recognized as an internal or external command,
'RIVE' is not recognized as an internal or external command,
'FF_PATH"' is not recognized as an internal or external command,
'/F' is not recognized as an internal or external command,
'F' is not recognized as an internal or external command,
'ORIGINAL' is not recognized as an internal or external command,
'InterlacedORIGINAL:' is not recognized as an internal or external command,
'nterlacedORIGINAL:' is not recognized as an internal or external command,
'""' is not recognized as an internal or external command,
'rate' is not recognized as an internal or external command,
'e' is not recognized as an internal or external command,
'NO' is not recognized as an internal or external command,
'ght' is not recognized as an internal or external command,
'----------------------------------------------------------------------------------------------------------------------------------------------------' is not recognized as an internal or external command,
'emode' is not recognized as an internal or external command,
'ce_mode' is not recognized as an internal or external command,
'e_value' is not recognized as an internal or external command,
'[' is not recognized as an internal or external command,
'cbr' is not recognized as an internal or external command,
The filename, directory name, or volume label syntax is incorrect.
'-s' is not recognized as an internal or external command,
'x1"=="[.vob" GOTO out' is not recognized as an internal or external command,
'x1"=="[.m2v" SET out_m2v=-threads & SET out_path=D:\' is not recognized as an internal or external command,
'-i' is not recognized as an internal or external command,
'OTO' is not recognized as an internal or external command,
'te' is not recognized as an internal or external command,
'ET' is not recognized as an internal or external command,
'_path' is not recognized as an internal or external command,
'ile' is not recognized as an internal or external command,
'-----------------------------------------------------------------------------------------------------------------------------------------------------' is not recognized as an internal or external command,
'ch' is not recognized as an internal or external command,
'GINAL' is not recognized as an internal or external command,
'INED' is not recognized as an internal or external command,
'FINED' is not recognized as an internal or external command,
'EFINED' is not recognized as an internal or external command,
'LOCAL' is not recognized as an internal or external command,
'1' is not recognized as an internal or external command,
'0' is not recognized as an internal or external command,
'HO' is not recognized as an internal or external command,
'O.' is not recognized as an internal or external command,
'O' is not recognized as an internal or external command,
'/A' is not recognized as an internal or external command,
The system cannot find the file specified.
'GTR' is not recognized as an internal or external command,
'LEQ' is not recognized as an internal or external command,
'EM' is not recognized as an internal or external command,
'1pass_VBR' is not recognized as an internal or external command,
'HQ_params' is not recognized as an internal or external command,
'"YES"' is not recognized as an internal or external command,
'CBR' is not recognized as an internal or external command,
'Fixed_Rate' is not recognized as an internal or external command,
'height' is not recognized as an internal or external command,
'288' is not recognized as an internal or external command,
'240' is not recognized as an internal or external command,
'oFix' is not recognized as an internal or external command,
'ont_touch' is not recognized as an internal or external command,
'local' is not recognized as an internal or external command,
'HO.' is not recognized as an internal or external command,
'mpeg.exe' is not recognized as an internal or external command,
'TO' is not recognized as an internal or external command,
'T' is not recognized as an internal or external command,
'NOT' is not recognized as an internal or external command,
'R' is not recognized as an internal or external command,
'ffmpeg.exe' is not recognized as an internal or external command,
Invalid parameter - =1-pass
Invalid parameter - =CBR
<01/16/2021 Sat 11:11:03.53>
File Name:
Encoding Mode: HQ: YES Custom Quant Matrix: Fox New
Executing first pass command generated by the ffmpeg-VBR plugin:
ffmpeg.exe
Executing second pass command generated by the ffmpeg-VBR plugin:
ffmpeg.exe
Multiplexing video and audio streams
Executing command: mplex -f 8 -S 0 -M -V -o "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg" "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg.m2v" "D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg.audio0"
INFO: [???] mplex version 2.1.0 (2.2.7 $Date: 2012/11/17 01:55:16 $)
**ERROR: [???] Unable to open file D:\DVDStyler\Temp\dvd-tmp\menu0-0.mpg_bg.mpg.m2v for reading.
Failed
What can I do to fix this? also, is this even the right way to make a Video_TS file? If not, how? I am a newbie so make it easier for me to understand please and thanks
Results 1 to 1 of 1
DVDStyler
By Sirbu in forum Authoring (DVD)Replies: 5Last Post: 15th May 2018, 11:55 -
DVDStyler Adding Pulldown?
By MrColeslaw in forum Authoring (DVD)Replies: 5Last Post: 9th Apr 2018, 15:50 -
How to fix DVDStyler error
By WhistlerJ in forum Authoring (DVD)Replies: 2Last Post: 20th Mar 2017, 10:24 -
Help With DVDSTYLER
By jcool26 in forum Authoring (DVD)Replies: 6Last Post: 8th Jul 2016, 08:11 -
DVDStyler Encoder
By jcool26 in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2016, 17:47
