My 10 year old samsung Sh-B083L BD burner won't load BDs so i'm thinkin' perhaps it needs a cleaning. What should i do ? Is the lens the only culprit and how to know
dvds work but BDs no luck (brand new or old). disc not detected anytime.I find that strange though, i have used BDs way less than dvds over the years
you can try. but it's usually a lost cause. open it up and use a cotton qtip with lens cleaner solution. use another to dry it off and more if anything still appears on the lens. DON'T use any downward pressure.
unless you are a 2 pack a day smoker that may have left tar on the lens it probably is just dead, normal dust and dirt is swept off the lens anytime a disc is inserted.--
I have in storage a Lens-cleaning CD. Basically a cd with a tiny horsehair brush glued to it. Bought it in 90s-early2000s and only ever used it once or twice. Didn't work.
Sounds like defective BD laser/lens assembly. 10 years old? Just get a new one.
Removing lens artifacts
By Wheaticus in forum RestorationReplies: 4Last Post: 30th Jun 2020, 11:23 -
canon or fujinon lens?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2019, 03:25 -
ZR700 aux lens
By ullrichr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Aug 2019, 17:33 -
HELP - lens distortion sony vegas
By un1ck in forum Off topicReplies: 1Last Post: 21st Nov 2017, 08:58 -
Panasonic NV-GS50 lens gone?
By CrazyBugga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 6th Oct 2016, 10:41
