Results 1 to 9 of 9
  1. my 3 sata dvd drives are having the same behavior even after I tested them on another pc, connect them they are recognized by windows and device manager, their led lights up and flashes, the tray system is not dead but none of the dvd’s q insert is read they even try to read but in the end if I click on the icon of the dvd drive on my computer asks to insert disk drive D :, what to do game all in the trash or still have to recover and make them good?
    Feb 2006
    try uninstalling the dvd drive via the device manager, restart your computer and let windows reinstall the drive.
  3. not work
    Mar 2008
    Do you have Imgburn installed? Open it up and go to
    tools/filter driver load order
    If any upper / lower class filters are installed, remove them and reboot.
    Second thing, try another SATA cable
    Jul 2007
    Be aware that this is gamemanico and his questions will probably never end
    http://www.digitalfaq.com/forum/computers/11390-dvd-drive-read.html
    Aug 2004
    PA USA
    Try throwing them in the trash, guaranteed to solve the problem. If they still don't work, throw away your computers.
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  7. i use imgburn, i tested emn another pc with another sata cable and the result was the same
    I throw the 3 drives in the trash or is it possible to recover them?
  8. Member Cornucopia's Avatar
    Depends on if the garbageman has picked up the bin or not.
  9. Originally Posted by Cornucopia View Post
    Good one.
