Hello.
Recently got ambitious to digitize my old VHS and VHSC home movies.
I'm a total DIY'er, and have just a simple Win7 desktop.
Bought an analog-to-USB converter off Amazon for $10, and it works.
Have successfully transferred some videos via OBS onto my 2TB external drive,
but the files are HUGE, as in 14GB for a two hour video.
I had the output resolution set at 864x540.
I'm trying another one with it set at 576x360 to see if that makes the file smaller.
All I care about is that I get all resolution the tape has, and that the videos aren't choppy.
Any advice is appreciated, and please be gentle on this digital-video-newbie.
Thanks in advance!
NTSC video should be captured at 720x480, interlaced, compressed with a lossless codec. Worry about cleanup and aspect ratio later.
There are better tools to perform this task than OBS. Also; video bitrate determines filesize not resolution.
If OBS is your way to go let me know your settings and i will advise. I'm not an expert or a purist, but I use OBS literally on a daily basis so can advise on a few of its settings.
You can manually type in your preferred resolution...
[Attachment 56806 - Click to enlarge]Last edited by codehound; 16th Jan 2021 at 05:51.
How to capture anything with Obs Studio
By Baldrick in forum User guidesReplies: 1Last Post: 8th Sep 2021, 01:10 -
OBS studio stand alone?
By mol3000 in forum Capturing and VCRReplies: 3Last Post: 14th Dec 2020, 08:51 -
How do I modify scaled size of an H.264 encoded video?
By kfitfk in forum Video ConversionReplies: 2Last Post: 21st Oct 2019, 21:59 -
Any Way to Get OBS to Flash a Message That You Are Currently Streaming?
By pone44 in forum Video Streaming DownloadingReplies: 9Last Post: 23rd May 2019, 09:02 -
Color Ghosting with OBS
By ArctiCMooN in forum Capturing and VCRReplies: 25Last Post: 26th Feb 2019, 20:33
