I'm using windows 10
SE worked fine until today, I tried opening it and the little blue circle appears, then disappears and nothing happens
in the task manager > details tab, the "SubtitleEdit.exe" first appears and then disappears a second or two later
does anyone know what's going on, it's bizarre
Results 1 to 12 of 12
Uninstall it and reinstall it.
Recreate the problem then open the Windows event viewer (eventvwr.msc) . Look at System and Application messages
for something related (they're usually sorted newest at the top) -
Try and do a restore before the problem happened.
I did the disk check this morning and it needed to repair stuff. After the obligatory restart, the system couldn't boot (every time there was a blue screen) so i did a Windows reinstall. It's working fine now. I'm guessing my SSD might be having problems so if there's a catastrophic breakdown I'll buy a new one. I have a separate HDD for data so it's not a problem, I'm not gonna lose anything.
Thanks for the help, as far as I'm concerned this is solved. -
I doubt the ssd was acting up,i had windows doing strange things such as corrupt restore points and programs not working as intended,doing a clean install fixed it.
AnonymousGuest
It may have something to do with this?
https://www.theverge.com/2021/1/15/22232589/microsoft-ntfs-windows-10-bug-icon-file-fl...bility-comment -
Subtitle Edit OCR Doesn't Recognise Capitals for W, O, V, U, etc.
By koberulz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2020, 02:50 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
Subtitle Edit Doesn't recognise my LAV Filters
By abrogard in forum SubtitleReplies: 1Last Post: 18th Sep 2019, 04:42 -
Help with MPD video download - HDS doesn't work anymore
By Khalel in forum Video Streaming DownloadingReplies: 71Last Post: 9th Feb 2019, 05:11 -
Last Windows 10 Update (April 2018) - MEGUI doesn't start anymore.
By Cunhambebe in forum Newbie / General discussionsReplies: 43Last Post: 21st Jun 2018, 02:57
