  1. Hi I wondered if there is a program that will convert DTS to AC3 or E-AC3?
    I used to use Popcorn on a bootcamp partition however since having to delete the partition I can no longer get this to work. A mac compatible program would be preferable or if not something I can control easily using Parallels virtual machine.
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    For Mac I wouldn't know, but eac3to (which has a GUI also) can convert dts to AC3.
    I also read somewhere that eac3to using ffmpeg could encode to EAC3 up to 6 channels, but I wouldn't know how to do that.
  3. DTS to AC3 can be done by clever FFmpeg-GUI.
    canada
    audacity will convert dts to ac3 for the mac,just also install the ffmpeg addon.
  5. Maybe it will work with the software Audio Encoders. More information you can find here https://www.videohelp.com/software/eac3to.
  6. Can't you just run ffmpeg.exe and convert it through command line? I know I've used ffmpeg for audio conversion in Linux Mint before (and from what I understand about Mac, is that it is mostly Linux under the hood). https://superuser.com/questions/624561/install-ffmpeg-on-os-x
