Hello I was wondering does the AJA Kona LHi support 720*480i 29.97? Also is there a way to tell the AJA Control Room v15.5 capture software to stop capturing after a certain amount of time?
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Seems like it does not support it:
https://www.aja.com/products/kona-lhi#techspecs'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Seems like 525i is the same as 480i.
https://en.m.wikipedia.org/wiki/480i
Is 525i 59.94 just 480i 29.97?Last edited by Waloshin; 13th Jan 2021 at 22:21.
Yes, Interlaced video counts the fields, 60 (59.94) fields per second is 30 (29.97) full frames per second.
Yes, 480i and 525i are the same thing. The analog signal is 525i but only about 480 lines contain picture content and are captured. Most of the other lines are just there for analog sync.
Here's a frame from a full 525 line capture:
[Attachment 56785 - Click to enlarge]
Most of those black/white dots near the top of the frame are from a broadcaster put a station logo in that portion of the signal. That area would normally be black and it wouldn't be visible on a normal TV.Last edited by jagabo; 14th Jan 2021 at 11:38.
aja kona lhi capture software
By hdfills in forum CapturingReplies: 5Last Post: 30th Dec 2020, 05:58 -
AJA KONA LHI vs. LHE for lossless VHS and Hi8 capture
By VIDEO VOID in forum CapturingReplies: 2Last Post: 14th Sep 2020, 00:59 -
VHS to pc transfer
By tvviewer in forum RestorationReplies: 2Last Post: 22nd May 2020, 15:33 -
What do we need to transfer VHS to CD?
By mikehende in forum CapturingReplies: 26Last Post: 16th Aug 2019, 18:39 -
Some help with cleaning up old VHS transfer
By autephex in forum RestorationReplies: 84Last Post: 9th Jan 2019, 17:59
