Results 1 to 12 of 12
you should specify what the problems are....
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
i tried that too, ignoring all read errors. it just stops at about 80ish % and says read error when the task says finished
if it starts and stops you likely have a bad drive. Try another one. If it was the protection it would not rip any part of it.
Am still using Ripit4me, DVD Decrypter and DVD Shrink, although I have not bought the DVD you mention, I have bought a lot of new DVD's and have not been stumped yet, Start Ripit4me, choose wizard mode and iso image, it will walk you through the steps, if Decrypter fails to import the PSL file, close decrytper and start again, sometime Ripit4me fails to create the file, once ripped to the hard drive use the "File" menu in DVD shrink, choose "Open Disk Image" once open go to "Edit" "Preferences and in the "output Files" tab uncheck "Split vobs into 1gb Chunks" then close that then choose re-author, you will see the different episodes in the right hand pain, drag them one at a time and have shrink copy them to the HDD, rename them as you go, remove the episode after it has finished and drag the next one into the right pain till you are finished, ripit4me may whine about the version of decrypter, ignore that, it's actually saying you need to update to the version you actually have, decrypters last version was 3.5.4.0 which is the version ripit4me will tell you you need to upgrade to, but it all works, just hit ignore each time.
Get unspecified error with MakeMKV on Star Trek: TOS blu-ray S1D7
By lmclouth in forum Blu-ray RippingReplies: 15Last Post: 15th Aug 2017, 07:47 -
Ripping Starfleet Access for Star Trek TOS Blurays.....
By primetime34 in forum Blu-ray RippingReplies: 29Last Post: 26th Jan 2017, 06:13 -
Star trek director's cuts
By P888 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jan 2017, 06:48 -
history and discovery channel ripping
By RBCC in forum Video Streaming DownloadingReplies: 4Last Post: 7th Oct 2016, 15:46 -
Star Trek fan fiction (episodes made by individuals)
By jimdagys in forum Off topicReplies: 5Last Post: 21st Sep 2016, 17:01
