So I usually record my gameplay through the Avermedia Live Gamer 4K and it's RECentral 4 software. It's a load of junk. I've had plenty of my videos get corrupted during some parts, and Avermedia is not helping.
Are there any other software alternatives or codecs that work with Amarec/Vdub allow support for NVENC encoding?Code:![]()
OBS would've been the perfect option...had it not been for the fact that I also record games from consoles that output oddball refresh rates (example: 59.83hz instead of 59.94hz). OBS doesn't really support custom frame rates for capture cards so there's a duplicate frame every 1000 frames or so. Really annoying since RECentral handles it better than OBS (even if there's a drop, it's not as bad as OBS).
I tried the good ol' ffmpeg command prompt and I cannot record at native resolution for the life of me because Avermedia can't be bothered to support common resolutions in their EDID. It's ridiculous.
Code:ffmpeg -f dshow -rtbufsize 2048M -video_size 1600x1200 -r (59830/1000) -i video="AVerMedia HD Capture GC573 1":audio="AVerMedia HD Capture GC573 1" -c:v h264_nvenc -preset slow -qp 18 -c:a copy -f segment -segment_time 362439 -strftime 1 "F:\~ffmpeg recordings~\output\%%Y-%%m-%%d_%%H-%%M-%%S.mkv"Amarec works fine with native res and oddball refresh, albeit only at YUY2 max instead of 4:4:4 RGB (despite working with 4:4:4 RGB on every resolution that's "officially supported", you can't even record 720p59.94 in RGB which is ridiculous). Is there's a GPU accelerated codec that'll work with it? NVENC really helps me out. I'm not looking to record losslessly. I'm just looking for a good quality capture.Code:[dshow @ 0000025115d3f7c0] Could not set video options video=AVerMedia HD Capture GC573 1:audio=AVerMedia HD Capture GC573 1: I/O error
Results 1 to 1 of 1
Best H265 gpu accelerated video conversion software
By Wolluf in forum Newbie / General discussionsReplies: 32Last Post: 18th Jul 2024, 13:13 -
Are there any capture software which support NVENC HEVC lossless recoring?
By Truthler in forum Capturing and VCRReplies: 20Last Post: 13th Aug 2020, 12:07 -
“ No NVENC capable devices found” with ffmpeg for screen capture and RTP
By ThadeuMelo in forum Capturing and VCRReplies: 1Last Post: 22nd May 2017, 17:43 -
Encoding Software for NVENC
By Desertdelphin in forum Video ConversionReplies: 2Last Post: 26th Feb 2017, 06:12 -
ffmpeg nvidia-gpu-accelerated encoding using NVENC - commandline settings
By hydra3333 in forum Video ConversionReplies: 3Last Post: 7th Sep 2016, 09:11
