Hello everyone,
as some years back I used this hack for my Panasonic DMP-BDT110
https://www.videohelp.com/dvdhacks/panasonic-dmp-bdt110/11413
Therefore my new Panasonic DP-UB450 (RC2 EU model) should get the same "update". As apparently it still works for this product generation - guessing from these:
https://www.videohelp.com/dvdhacks/panasonic-dp-ub820/12859
https://www.videohelp.com/dvdhacks/panasonic-dp-ub320/12861
I picked up my OFA URC7490 as purchased back then and programmed it again with the given sequences.
Applying buttons 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 to the player however - it does not work. No reboot. RC1 DVDs are defined as wrong region.
When pressing the first button "1" for code 00191 a menu for video selection "Disc or USB" comes up. Can anybody confirm, that this is the correct behaviour for this sequence?
Reprogrammed "1" three times - always the same behaviour.
Remote itself turns the player on/off correctly - so I guess the base "0490" is working fine.
Thanks for any ideas on how to get this player working (without spending more on a pre-programmed eBay-remote or enhanced firmware "been there, no success").
cu,
einnarr
i would suggest getting one of these - https://www.ebay.com/itm/Panasonic-DVD-Blu-ray-player-multi-region-hack-remote/1106026...k%3A1%3Apf%3A0 your player is on the list.
see this video for proof - https://www.youtube.com/watch?v=86G99uzU0Ec -
Is anyone still reading this?
Ran into the same problem (using OFA 7556), first "magic" button (00191) is OK/Enter (see https://www.hifivision.com/threads/panasonic-dmp-bdt220-anyone-lucky-making-it-region-...29/post-490834).
I ordered https://www.ebay.de/itm/353894539495
and will report back results:
Remote arrived today and it worked on my DP-UB450EG on the first attempt.
FYI:
1. No disc inserted
2. Pressed OK on the original remote 2x (Videos -> Disc)
3. When message "No disc inserted" appeared I applied the hack remote (message "1B" appeared on lower right corner).
4. Waited 10s, unplugged player, waited 5s, powered up again
5. Used Region 2 and 4 DVD to confirm: player is region free
I still don't know why it didn't work with the OFA remote, but the button sequence is transmitted much faster than I expected (i.e. not the ~1s interval mentioned in the original hacks).
I bit pricey to play some old DVDs from my collection, but I could set as many Panasonic players free as I wished now...Last edited by ratkat; 6th Feb 2024 at 14:53. Reason: added results and details
Panasonic V770 looking for a zoom remote control ??
By cjogo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Feb 2019, 23:19 -
Sony BDP-S6500 OFA control code?
By brex in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Mar 2018, 18:07 -
Sony BDP S370 DVD region hack - which remote to use!?
By bubbafurn in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2017, 06:49 -
Panasonic HC-X920 and remote controll
By Stile in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th May 2016, 19:12 -
Remote control region code hack for Sony home theatre
By KoolSky in forum Newbie / General discussionsReplies: 5Last Post: 18th Jan 2016, 08:00
