I was encoding a video file with Adobe Media Encoder CC 2019 when the computer went to sleep because of a loss of power. Out of curiosity, I restarted the process: I renamed the output file, reset the status of the encoding job, and launched it again. The result is different since it has a different number of bytes:
I watched both files and do not see a difference. I suspect that the difference comes from compression, whose result may allow for random bits. If it were only that, the files would have the same size in bytes and different bit values. But here, the file size is also different.Code:$ ls -lat ep16_3* -rw-r--r--@ 1 user staff 591181005 11 Jan 10:01 ep16_3.mp4 -rw-r--r--@ 1 user staff 591178262 11 Jan 09:04 ep16_3_interrupted.mp4
Why does this hapen, and how to inspect the difference between the files?
If the encoder has VBV buffer, the output is not deterministic afaik. What are your settings? Adobe Media Encoder probably uses Main Concept encoding library which uses VBV for constant and variable bitrate modes.
Thanks. My settings were "Match source - High bitrate". Yes, Adobe Media Encoder seems to have Main Concept encoding built-in: http://www.digitalfaq.com/forum/video-editing/7960-adobe-premiere-cs3.html.
x264 PRO Plugin for Adobe Premiere/Media Encoder stopped working
By Sithtronic in forum Video ConversionReplies: 4Last Post: 2nd Sep 2020, 09:10 -
please help me to encode a conCAT of mp4 input files?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2019, 03:10 -
264 or 265 encoder 10bit input format
By CommanderLake in forum Video ConversionReplies: 3Last Post: 12th Jul 2018, 17:31 -
Using Adobe Media encoder for a closed captioned DVD
By Digibird in forum Latest Video NewsReplies: 1Last Post: 29th Jan 2018, 12:24 -
PCM interleave discrepancy - Adobe Media Encoder vs. VirtualDubMod
By moxiecat in forum Video ConversionReplies: 10Last Post: 17th Jan 2018, 08:43
