After loading an mkv video, I choose video effects, adjustment, brightness/contrast/gamma. After these choices I can make changes, but I cannot see the changes. How do I make the video visible so that I can see the changes I am making?
Without even knowing what tool you are using my guess would be that there might be a 'Preview' somewhere which allows to see the effect of your settings on the input,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
The program is nVSDC Video Editor. I think the answer is along the timeline, where you can advance the video to a frame which contains an image you want to modify, according to the video effect you have chosen. Then you can see the changes, after which you can reset the timeline to the beginning and then begin the export,
It is a very powerful editor, whose depths I am just beginning toi explore. -
Just Tried it out. Click Playback tools at the top of the screen and the Menu below your video will change to include play.
Potplayer Video Effects?
By vanbrocklin in forum Software PlayingReplies: 0Last Post: 6th May 2020, 22:57 -
video effects
By jay666 in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2019, 03:31 -
What are these video effects and how to recreate them?
By mmexp in forum Newbie / General discussionsReplies: 1Last Post: 15th Oct 2019, 11:12 -
sound effects and video effects used in japan tv shows
By rocco123 in forum EditingReplies: 0Last Post: 30th Oct 2018, 11:16 -
Windows 7 video player that can save URL videos with applied video effects?
By coolvibe in forum Newbie / General discussionsReplies: 7Last Post: 13th Jun 2016, 17:52
