befor i even start:
asus a7v
athlon 1.4
512 megs
geforce2 mx
veiwsonic 90f
win2k sp2
latest 4 in ones, detonators etc
ok...im not even that sure how to explain this. Ive searched all over the web for help to no avail. When i play back video at a decent resolution (including dvd, divx, mpg everything) i get what i can only call horizontal "scanlines". This happens only when thers alot of action in the movie. It looks almost like its struggling to keep up with the framerate. I thought it was just my monitor or video card. But then I installed win98 and no problem at all! This only seems to happen under win2k even when running at the lowest of resolutions. A simple solution would just be "run win98", but ummm nah...i dont think so
TIA for any help. Im not really too sure how to explain whats happening so im sorry if im not being totally clear.
In my experience, these lines are normally caused by interlacing being used and is very noticeable with a lot of movement. With the action occurring, there are issues determining the "interlaced" lines in the clip and it fills them in incorrectly.
My guess on the fact that it works on Win98 and not on Win2k would probably center around the video codecs installed on your system. The codecs used on Win98 are probably more mature with respect to the OS than those on Win2K. It is always small problems like this that are hard to track down, but that would be my guess. Hope it helps.
Kevin
Video playback problem
By magiccastle in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 06:07 -
Video playback with audio problem.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2010, 05:50 -
XviD video playback problem
By mictsekk in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Jul 2009, 10:16 -
Problem with 4:3 Video Playback
By pantyryder69 in forum Software PlayingReplies: 9Last Post: 9th Feb 2009, 17:31 -
WMVHD Playback problem on a particular video
By huthmakerj in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Jul 2007, 14:41
