Hello,,I have about 50 hdv tapes from the sony hdr fx1 camcorder.I'd like to digitize them and the current options are
1)I have an older sony vaio laptop that has an i-link 4pin jack with sony vegas 8 and xp but after following the programs help instructions and the sony cam pamphlet the camcorder is not being recognized.I'm pretty sure I followed them correctly(It recognized it about 12 years ago when I did digitize part of a tape)
2)I have a newer Asus desktop windows 10.1 with sony vegas 12 but would need a firewire port/card added to my pc.
if I can get the laptop to recognize the camcorder I'd use that for now and both the laptop and camcorder seem to work fine with low use over the years.the cable itself is practically new and not sure if thats an issue.It seems to make sense to get the new firewire port but wondering if anyone has any suggestions? thank you
I had quite few HDV tapes from the FX1 that I've owned back in 2006 and I transferred them using HDVSplit before I sold it and move to a memory media camcorder on a Sony VAIO laptop via iLink on Wind7 with no problems, Make sure the camcorder is set to HDV not DV before you connect it to the firewire otherwise it will not work with HDVsplit.
a cable is cheap, it might be the problem, but the only way to know for sure is to test each piece to verify them. first you need to test the cams firewire port by taking it to another computer with a known working firewire port and cable. if it works there then you know it's either your cable or computer port. or borrow a known good firewire device to test your cable/port. sadly the firewire port on cams are all very fragile as the socket is only surface soldiered onto the mainboard.
thanks again,I have no way to find another computer with a working firewire so Ill have BestBuy test things out.
Sony HDR-FX7 Drivers
By Jeff Marolf in forum Latest Video NewsReplies: 13Last Post: 10th Jul 2020, 15:04 -
deciding on laptop to best capture minidv , Hi8 and HDv video tapes
By peterellen in forum Capturing and VCRReplies: 5Last Post: 24th Apr 2020, 05:32 -
Problems getting iMovie to recognize my old Sony HDR-HC5
By rikard454 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 18th Feb 2019, 04:26 -
Sony HDR XR160 alternative
By ibelieve in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Jul 2018, 12:20 -
suggestions on capturing HD tapes from a dead Sony HDR HC1E handycam?
By japniz in forum Capturing and VCRReplies: 12Last Post: 23rd Jan 2016, 08:08
