Hi, I recorded a video from an app on my android tablet using AZ Screen Recorder. The result was a video with the audio and video that is out of sync. Can I use Any Video Converter 7.07 on my PC to convert that video wherein the audio and video are in sync? If so, please walk me through that process. Please take into consideration that I am not very technical.
I very much appreciate your help.![]()
Is it constant or increasing or irregular A/V asynchrony?
In the case of constant asynchrony, you can remux video and audio with the corresponding audio delay; in the other two cases it is much more difficult, maybe even impossible. -
I double posted? If I did, I don't know how I did that. Like I said, I am not very technical.
As to your response, I do not understand anything that you said. Is there a simple way for me to understand it? What exactly do I need to do in AVC to get this to work?
Wondershare Video Converter Ultimate 10.4.2 - Water Mark Possible?
By CarpentarMate in forum Video ConversionReplies: 2Last Post: 25th Feb 2019, 14:03 -
Wondershare Video Converter Ultimate doesn't run
By Khalel in forum Video ConversionReplies: 4Last Post: 15th Jul 2017, 16:24 -
Xilisoft Video Converter Ultimate wrong info in properties
By Vid Bro in forum Video ConversionReplies: 1Last Post: 16th Jun 2017, 14:50 -
Convert to an exact file size with Wondershare Video Converter Ultimate
By KT888 in forum Video ConversionReplies: 19Last Post: 3rd Jun 2017, 00:27 -
Problems with Xilisoft Video Converter Ultimate
By Diokamos in forum Newbie / General discussionsReplies: 8Last Post: 6th Feb 2016, 10:36
