I have an European VCR, a PAL TV and some VHS tapes in PAL-M (Brazil). In the VCR, it says "NTSC playback on PAL TV". The tapes play fine on the TV but when I try to convert it to digital using a video capture, the image is in black and white. Does anyone know what kind of signal does the VCR output? PAL-M? PAL60? NTSC 4.43?
I've tried different approaches to solve this but nothing worked. I just had this idea:
- Buy a SCART to HDMI converter compatible with PAL, NTSC3.58. NTSC4.43, SECAM, PAL-M, PAL-N (my VCR only outputs SCART)
- Buy an HDMI video capture
Connect the HDMI video capture through USB 3.0 to the computer.
Would it work?
Thank you.
PAL vcrs with NTSC playback output PAL60.
I doubt if your 'idea' would work.
There are capture devices that support PAL60 but they will not work either with this rather unique standard.
You should not get colour from your vcr but it seems that certain models do support it.
https://en.wikipedia.org/wiki/PAL-M -
No. (placing my head above the parapet) I do not think NTSC 4.43 is the same as PAL60
PAL60 is standard NTSC 3.58 with the colour sub-carrier 'converted' to PAL
By the same token PAL-M is also not NTSC 4.43 since the former has all the qualities of NTSC 3.58 apart from the colour signal. (Hard hat still on)
Many moons ago I did own one PAL-M tape since a friend of mine from Brazil sent a tv recording to me. I could not get any colour signal from it either on my tv or through capture equipment and I had to send it away to have it converted by someone who had multi-standard vcrs -
Just an update, if anybody else is facing the same problem with PAL-60: My idea worked, but for some annoying reason the HDMI video capture sometimes cannot recognize the signal coming from the converter. Sometimes I connect the HDMI cable from the converter to the HDMI video capture and image appears on the computer (with really good quality), but other times it doesn't, but it doesn't seem like the problem is the capture because if I connect my PS4, then it works as it should. If I don't manage to find a solution to this, the only thing that I have in mind is trying the Hauppauge USB-Live2, from what I read here it can capture PAL-60.
Troubleshooting transfer of VHS tapes to digital
By Kajaboss in forum MacReplies: 10Last Post: 19th May 2020, 16:37 -
PAL VHS to Digital Conversion in USA
By greenscreen2017 in forum Video ConversionReplies: 9Last Post: 21st May 2019, 09:56 -
Converting Hi8 analog tapes to digital
By mrittman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 26th Aug 2018, 14:58 -
Is it true all PAL VCRs can play NTSC, PAL, SECAM tapes?
By digicube in forum Capturing and VCRReplies: 26Last Post: 16th Sep 2017, 11:20 -
Digital 8 tapes showing wear
By jstevens30 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th Jan 2016, 13:11
