There's a program that I simply wanted to watch on a different device than online, so I downloaded its file. It's over 1 GB so I'm pretty sure it's the real deal.
But... when you play if it's just a green screen with a few block artefacts and no audio either.
Is there software that removes this?
I can google a number of programs that claim to remove DRM, but will they work in cases like these? Anyone got experience with this?
I can send an example if necessary.
Results 1 to 14 of 14
This is nøt å signåture.™
"mp4decrypt"
you will need keys tho.
what is the url? or which software you downloaded that video from?discord=notaghost9997 -
Say for example this program: https://www.npostart.nl/oudejaarsconference-2020/31-12-2020/BV_101404266
Are those keys that I'd need somewhere in the html or other code?
(I'm not too lazy to google but often you get oudated results, or you have to install twelve programs until one actually works, etcetera.)This is nøt å signåture.™ -
keys cannot be obtained trough html use http://www.downloadgemist.nl/ goodluck
these keys may not work on 1080p because i only had access to lower qualities.
KID:"85447fdeefbefa7e66cb08bc55e01fb4" , KEY:"dd225a76cbb974a9d2a92974ee0a69f1"
[Attachment 56680 - Click to enlarge]
there used to be ways to get keys with javascript reverse engineering but it is very rare.
here is demonstration to get keys from Youku which obviously does not work anymore.
https://imgur.com/3y1zmcrdiscord=notaghost9997 -
Oh right, this is a different site from gemistdownloader.
for the decryption part if you got the encrypted video file you simply use mp4decrypt you can google for bento4 and download the folder and you only need mp4decrypt drag it to somewhere for example to your desktop and open a cmd window do cd Desktop or cd Bureaublad or whatever it is named i took example keys from above and you simply do mp4decrypt --key 85447fdeefbefa7e66cb08bc55e01fb4:dd225a76cbb974a9d 2a92974ee0a69f1 "yourdecryptedvideofilehere" "nameyouroutputefilewhateveryouwant.mp4" or you can also do it with only the key like this mp4decrypt --key 1:dd225a76cbb974a9d2a92974ee0a69f1 "yourencryptedvideohere" "decrypted.mp4" so first the kid after the : the key second example you only need the key you place it after the 1: and repeat this for the audio file to! goodluck
After decrypting the segments, can you keep the old manifest?
Do you have to change/remove #EXT-X-MAP:URI="init.mp4?
Web player doesn't play with #EXT-X-MAP included, and only plays the first chunk without it.
Can you perhaps edit init.mp4 to assert the segments are no longer encrypted.
It's AVC1 codec.
For example, ORIGINAL:
#EXTM3U
#EXT-X-VERSION:7
#EXT-X-TARGETDURATION:6
#EXT-X-MEDIA-SEQUENCE:5755
#EXT-X-INDEPENDENT-SEGMENTS
#EXT-X-MAP:URI="init.mp4"
#EXT-X-KEY:METHOD=SAMPLE-AES-CTR,URI="data:text/plain;base64,xxxxxxxx",KEYID=0x1234567890123456789 0123456789012,KEYFORMAT="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed",KEYFORMATVERSIONS="1"
#EXTINF:6.006000,
5755.mp4
#EXTINF:5.989317,
5756.mp4
#EXTINF:6.006000,
5757.mp4
#EXTINF:6.006000,
5758.mp4
#EXTINF:5.989316,
5759.mp4
AFTER:
#EXTM3U
#EXT-X-VERSION:7
#EXTINF:6.006000,
decrypted_5755.mp4
#EXTINF:5.989317,
decrypted_5756.mp4
#EXTINF:6.006000,
decrypted_5757.mp4
#EXTINF:6.006000,
decrypted_5758.mp4
#EXTINF:5.989316,
decrypted_5759.mp4Last edited by hans_305; 12th Jan 2021 at 10:36.
Trying to remove the drm protection from itunes video
By shadshood in forum Video ConversionReplies: 9Last Post: 17th Sep 2021, 03:32 -
How download a MPEG Dash with DRM?
By Marven in forum Video Streaming DownloadingReplies: 2Last Post: 15th May 2020, 15:55 -
How to Remove DRM Protection from iTunes Videos?
By DVDFab Staff in forum User guidesReplies: 4Last Post: 7th Jan 2020, 14:54 -
Can somebody help me to download this m3u8 videos with DRM?
By blansac in forum Video Streaming DownloadingReplies: 6Last Post: 5th Nov 2019, 13:35 -
Download: mpeg-dash + drm
By kall in forum Video Streaming DownloadingReplies: 1Last Post: 25th Mar 2017, 07:31
