I mostly use emulator or frontend programs to record my gameplay but while I used the built in recording function, I was also advised of another method to record my videos on. I had heard that you can record virtually any PC footage using OBStudio but how do you go about doing that? I also have a Record AVI function in VRtualdub2, should I use that do?
OBS supports both recording (save to storage) and streaming (send to URL) types of capturing. It allows for multiple types of "sources" - USB-type "webcams" and other live video capture sources, text feeds, etc. One of the MAIN source options is SCREEN captures. It can be a full screen (taken likely as a tap from the video card's or driver's memory buffers), or a window.
AFAIK, Virtualdub apps might not support screen capture/recording, but they do support the USB/UVC "webcam" and other live video sources (VFW-based, or possibly DirectShow-based).
If you are doing gaming and trying to record them, OBS screen capture is a very good choice - if your system is capable enough to support doing both the gaming AND the recording without loss of performance.
If it is NOT enought to support both, I would suggest you consider using a capture computer system separate from the gaming computer system.
ScottLast edited by Cornucopia; 6th Jan 2021 at 22:38.
OBS is not capturing -- it's recording. Screen recording. It has rudimentary useless analog capture abilities.
VirtualDub is actual capturing of analog source. It has rudimentary useless screen recording abilities.Want my help? Ask here! (not via PM!)
I think this maybe sound advice as my laptop may not be up to snuff for game capturing or recording. I will have try to use OBS but I am not sure if my current laptop is capable of doing this.
I see. Looks like I am going to have to find a compromise.OBS is not capturing -- it's recording. Screen recording. It has rudimentary useless analog capture abilities.
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 05:25 -
Help with Brazilian site in .MPD I can no longer record videos in .MP4
By marciovas in forum Off topicReplies: 1Last Post: 23rd Sep 2018, 15:58 -
Best way to record YouTube paid videos ?
By DonSeenu in forum Video Streaming DownloadingReplies: 1Last Post: 13th Apr 2017, 10:47 -
How to stream videos and record them directly from TV
By lucky113 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Sep 2016, 22:13 -
Are there pre-set timers to record videos ?
By Arcadiune in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2016, 19:08
