I was given this thread talking about the GOP settings in Handbrake:
https://forum.videohelp.com/threads/391526
but I don't see where to actually *change* the setting in the GUI. Or are they talking from the command line?
gops don't have anything at all to do with the quality of the video. open gops are used to reduce the size of the video file by a tiny amount, but at the expense of editing. closed gops are always preferred for editing. if you are producing end user video just use the defaults.
I was told that Handbrake creates very long GOPs which slow down seeking and initial playing, especially with HEVC files because they take lots of CPU to decode.
I was told that a smaller GOP will help me for a specific project I am working on. The video editor I'm using works better with smaller GOPs. -
You specify the GOP size in the Extra Options box. Enter "keyint=60" (without the quotes) or whatever value you want. I don't know if it's the same for all codecs but that works for x264, x265, QSV h.264 and QSV h.265. You may also want to change keyint_min, "keyint=60:keyint_min=10".
Handbrake GOP setting
By jseo13579 in forum EditingReplies: 13Last Post: 27th Sep 2020, 20:11 -
How to change default of a soundtrack/language with PotPlayer
By pintree3 in forum Software PlayingReplies: 2Last Post: 23rd Feb 2020, 08:02 -
Is there an easy way to change default Audio/Subtitles?
By GiesbertsN in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2019, 05:54 -
Is dynamic GOP the same as closed GOP. GOP of half the frame rate?
By Chibi in forum EditingReplies: 3Last Post: 31st Aug 2017, 14:33 -
Is it possible to change a default setting for an Avisynth plugin?
By hello_hello in forum EditingReplies: 0Last Post: 9th Aug 2016, 05:41
