I have many miniDV tapes which I used a Canon VIXIA HV30 camcorder. I have long since sold this camcorder (why?) and now I want to get all that footage off these tapes and on disk (PlexTV and DVD to family).
Should I look for a used HV30 camcorder or will any HDV camcorder do?
Results 1 to 9 of 9
in theory any HDV cam/deck would do. but not all heads are aligned the same and not all cams had the same features. like if you recorded in 30p a lot of cams wouldn't recognize it. so first pick would be your old hv30, 2nd another hv30, 3rd an hv20 or hv40, last any other HDV cam/deck.
I've captured my HDV on a few cameras/decks other than the Sony FX1 on which they were recorded. I did not have a problem. Back in the day (20 years ago) there were lots of rumors that if you changed from one tape brand to another while capturing a bunch of tapes, that the residual coating from the previous tape formulation would cause a problem. I never experienced that, but it's another thing to keep in the back of your mind.
I agree that the same camera model would probably be the best choice, but having transferred DV tapes on lots of different cameras and decks, all different than the recording device, and never had a problem, you probably will be OK no matter what you do with your HDV transfers. -
The only thing the OP should worry about is if his files are progressive, Only one model or two consumer camcorders were able to record in progressive and I think the HV30 is one of them, So getting the same model is safer. Though HV30 recorded 1080p from external sources only not from the camera lens according to Wikipedia.
As I remember, "progressive" mode with DV and HDV NTSC cameras was 24p. However, since all TVs were still hardwired to 29.97 fps interlaced (NTSC) or 25 fps interlaced (PAL) the DV had to conform to that, so the camera added telecine. As a result, when capturing these tapes, the video is standard 29.97 or 25 fps interlaced, and you don't need to do anything special. If course if you are going to edit or do anything with it, you should IVTC before you do anything.
That only applies to DV, HDV recorded in 24p, 25p and 29.97p (30p) and I have a deck that records all of them. HV20/30 did that in VCR mode only, If all the OP videos are shot thru the lens he should be fine with any HDV camcorder.
NO. "any HDV" cam will NOT be ok. there are some JVC HDV cams that only record/play 720p60.
Archiving MiniDV tapes but they all start to have audio skipping
By hpcampr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 19th Feb 2020, 12:18 -
minidv tapes breaking up
By hdfills in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2018, 17:48 -
miniDV tapes are deteriorating. Can't convert to DVD. Am I doomed?
By foton24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 6th Jul 2018, 19:56 -
Why is the audio distorted on these MiniDV tapes?
By Hypersonic1 in forum Capturing and VCRReplies: 14Last Post: 18th Apr 2018, 19:04 -
How to transfer minidv video tapes to digital videos
By OldViddy in forum User guidesReplies: 6Last Post: 4th Dec 2016, 09:54
