Results 1 to 11 of 11
  1. Member dashas's Avatar
    Jul 2010
    Yandina Sunshine Coast Qld Australia
    Hi all i m not sure where to paste but as a Newbie last was 2010 I am in need of you assistance
    I have a Problem with YouTube it was fine on friday when I last used it but now YouTube has sound' but no video? Face Book and all other Web Browser media is working the only thing I was thinking was Java ?? They dont have that anymore I think
    I have cleared Historys, Cache etc in Firefox and Edge (I dont use Edge or Chrome) and done all I know how to do which is not much?
    Any help would be appreciated Regards Dasha
  2. Member dashas's Avatar
    Jul 2010
    Yes Mate thats It? Do you know anywher else I can post to get help over this issue Thanks Dasha
  3. Member DB83's Avatar
    Jul 2007
    Can you post a link to the youtube video you are having issues with ?
  4. Member dashas's Avatar
    Jul 2010
    https://www.youtube.com/watch?v=7_TaK0WZj2k
    https://www.youtube.com/watch?v=Ctys86aNk1A
    Cheers Mate
    Mar 2008
    Cheers Mate
    Did you right click, "stats for nerds" to see what codec is being used?
  6. Member dashas's Avatar
    Jul 2010
    Cheers Mate
    No I did not even know there was a place to do that I am an newoldbie I have not been here since 2010
  7. Member DB83's Avatar
    Jul 2007
    No surprise that both vids, and any other, play fine in both my usual browsers.
    The vids in question use the AVC1 codec so I doubt the issue is the browser considering that other web sources are fine. Possible that you do not have the codec installed so here is the downloaded first vid. Can you play that ?
  8. Member dashas's Avatar
    Jul 2010
    G/Day Thanks thats fixed the Issue or told us how too. I did think Codec's but I have been playing these Clips forever on Y T and its never missed a beat, so I coluld nothave thought of that being the Issue and only cropping up a week ago?
    So what has caused this has that Codec been changed how do replace it or fix it I have the KCodecs Pack somewhere on this PC but they are old or should I just Google -it and find one and try and Install that into >progams >YouTube Folder?
    Cheers dashas
    Feb 2006
    Cheers dashas
    what browser are you using and is it up to date ??
  10. Member DB83's Avatar
    Jul 2007
    ^^ The OP stated he/she is using Firefox (could not mind up if using Edge)
    YT changed their base codecs many months ago so if they played fine a week or so the issues will not be codec related.
    A quick Google led me to this
    https://www.drivereasy.com/knowledge/how-to-fix-youtube-videos-black-screen-easily/
    Check option 4 or the 'sign out' option
    There are many posts with these issues and a Google of 'no video on Youtube' will call up a pile.
    Adblockers and general internet issues (failure to load the video) may also be the culprit (from these results). So here is another result from the search
    https://www.lifewire.com/youtube-black-screen-4178316
  11. Member dashas's Avatar
    Jul 2010
    ^^ The OP stated he/she is using Firefox (could not mind up if using Edge) [/NOT EDGE]
    [/I 'm using the latest Firefox Browser]
    [/ Disable the ad blocking extension, such as Adblock or Adblock Plus, in the extensions settings on your web browser:
    This was the answer DB Treid all of the rest and This was it ALSO Block Ad Frames in YouTube Videos Another App thaI deleted and it worked the latter was only a recent addition AD Block has been there forever
    [/It was indeed the Adblockers and Block Ad per Frame' in Youtube only causing all the trouble]
    Well Done DB and all of you thanks soo much ]
    I am ready to ask other stuff about Chromecast Dongle, streamig to my Sony Bravia TV at another thread thanks again Kindest Regards Dazzler
