Hello friends, first of all sorry for my English, I'm using google translator, because I'm Brazilian.
I would very much like your help.
So, I'm trying to download videos from two online tv streaming sites, but to no avail. The site doesn't have a drm, but I still can't download the stream. The link that takes me to the .m3u8 file gives me "access denied" I tried several ways with youtube-dl, and I also tried with m3u8x, but I can't do it at all. The idm can download the .ts file for 1 min as soon as I start the video, it uses the same url as the .m3u8 file but youtube-dl and m3u8 cannot access the file to download it.
I don't understand much, but I can learn, if someone is willing to help me. I look forward to returning, thank you very much!
The site is this one: https://multicanais.com/assistir-viva-online-hd-24h-no-ar/
Results 1 to 11 of 11
youtube-dl --add-header "referer: https://esporteone.com/player/canais.php?canal=VIVASD" "https://live.netcanais.com/VIVASD/video.m3u8"
discord=notaghost9997 -
Hello friend, thank you so much it worked! There is only one problem, the file starts to download, and in less than 3 seconds, it freezes. I don't know what happens, but it crashes and doesn't download anything else. After a few seconds or minutes it starts to download the other segments
but it displays the error "HTTP error 403 Forbidden"
Is there any way around this? The same command works perfectly on another site, without any access denied error.
Code:c:\youtube-dl>youtube-dl --add-header "referer: https://esporteone.com/player/canais.php?canal=VIVASD" "https://live.netcanais.com/VIVASD/video.m3u8" --verbose [debug] System config: [] [debug] User config: [] [debug] Custom config: [] [debug] Command-line args: ['--add-header', 'referer: https://esporteone.com/player/canais.php?canal=VIVASD', 'https://live.netcanais.com/VIVASD/video.m3u8', '--verbose'] [debug] Adding header from command line option referer: https://esporteone.com/player/canais.php?canal=VIVASD [debug] Encodings: locale cp1252, fs mbcs, out cp850, pref cp1252 [debug] youtube-dl version 2021.01.03 [debug] Python version 3.4.4 (CPython) - Windows-10-10.0.19041 [debug] exe versions: ffmpeg 4.3.1, ffprobe 4.3.1 [debug] Proxy map: {} [generic] video: Requesting header [generic] video: Downloading m3u8 information [debug] Default format spec: bestvideo+bestaudio/best [debug] Invoking downloader on 'https://live.netcanais.com/VIVASD/video.m3u8' [download] Destination: video-video.mp4 [debug] ffmpeg command line: ffmpeg -y -loglevel verbose -headers "Cookie: __cfduid=d806c11932d51123a1eb0e862e15de91b1609833444 referer: https://esporteone.com/player/canais.php?canal=VIVASD Accept-Language: en-us,en;q=0.5 User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3568.0 Safari/537.36 Accept-Encoding: gzip, deflate Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 " -i "https://live.netcanais.com/VIVASD/video.m3u8" -c copy -f mp4 "file:video-video.mp4.part" ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 10.2.1 (GCC) 20200726 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [tcp @ 00000254a3cf13c0] Starting connection attempt to 172.67.72.84 port 443 [tcp @ 00000254a3cf13c0] Successfully connected to 172.67.72.84 port 443 [tls @ 00000254a3cf1180] Error in the pull function. [hls @ 00000254a3ced040] Skip ('#EXT-X-VERSION:3') [hls @ 00000254a3ced040] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-01-05T07:55:37Z') [tls @ 00000254a3cf1180] The specified session has been invalidated for some reason. Last message repeated 1 times [hls @ 00000254a3ced040] HLS request for url 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/12-05000.ts', offset 0, playlist 0 [hls @ 00000254a3ced040] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/12-05000.ts' for reading [tcp @ 00000254a42a2d80] Starting connection attempt to 172.67.72.84 port 443 [tcp @ 00000254a42a2d80] Successfully connected to 172.67.72.84 port 443 [hls @ 00000254a3ced040] HLS request for url 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/17-05000.ts', offset 0, playlist 0 [hls @ 00000254a3ced040] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/17-05000.ts' for reading [tcp @ 00000254a4555180] Starting connection attempt to 172.67.72.84 port 443 [tcp @ 00000254a4555180] Successfully connected to 172.67.72.84 port 443 [NULL @ 00000254a42a03c0] non-existing SPS 0 referenced in buffering period [h264 @ 00000254a46de380] non-existing SPS 0 referenced in buffering period [h264 @ 00000254a46de380] Reinit context to 640x368, pix_fmt: yuv420p Input #0, hls, from 'https://live.netcanais.com/VIVASD/video.m3u8': Duration: N/A, start: 79690.121944, bitrate: N/A Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (High), 1 reference frame ([27][0][0][0] / 0x001B), yuv420p(left), 640x360 (640x368) [SAR 1:1 DAR 16:9], 30 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Output #0, mp4, to 'file:video-video.mp4.part': Metadata: encoder : Lavf58.45.100 Stream #0:0: Video: h264 (High), 1 reference frame (avc1 / 0x31637661), yuv420p(left), 640x360 (0x0) [SAR 1:1 DAR 16:9], q=2-31, 30 tbr, 90k tbn, 90k tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (HE-AAC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help Automatically inserted bitstream filter 'aac_adtstoasc'; args='' [hls @ 00000254a3ced040] HLS request for url 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/22-05000.ts', offset 0, playlist 0 [https @ 00000254a4362a40] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/07/57/22-05000.ts' for reading [tcp @ 00000254a472d7c0] Starting connection attempt to 172.67.72.84 port 443ts/s speed=9.07x [tcp @ 00000254a472d7c0] Successfully connected to 172.67.72.84 port 443 [hls @ 00000254a3ced040] Skip ('#EXT-X-VERSION:3') [hls @ 00000254a3ced040] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-01-05T07:55:37Z') [https @ 00000254a47a9240] Opening 'https://live.netcanais.com/VIVASD/video.m3u8' for reading [AVIOContext @ 00000254a4efa640] Statistics: 1091 bytes read, 0 seeks [tcp @ 00000254a3cf3780] Starting connection attempt to 104.26.7.188 port 443 [tcp @ 00000254a3cf3780] Successfully connected to 104.26.7.188 port 443 [hls @ 00000254a3ced040] Skip ('#EXT-X-VERSION:3') [hls @ 00000254a3ced040] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-01-05T08:02:22Z') [hls @ 00000254a3ced040] skipping 59 segments ahead, expired from playlists [hls @ 00000254a3ced040] HLS request for url 'https://live.netcanais.com/VIVASD/2021/01/05/08/02/22-05000.ts', offset 0, playlist 0 [https @ 00000254a4362a40] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/08/02/22-05000.ts' for reading [AVIOContext @ 00000254a4397f40] Statistics: 1236288 bytes read, 0 seeks [hls @ 00000254a3ced040] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/08/02/22-05000.ts' for reading [tcp @ 00000254a4d69840] Starting connection attempt to 104.26.7.188 port 443 [tcp @ 00000254a4d69840] Successfully connected to 104.26.7.188 port 443 [https @ 00000254a3cf3840] HTTP error 403 Forbidden [hls @ 00000254a3ced040] Failed to open segment 20638 of playlist 0 [hls @ 00000254a3ced040] HLS request for url 'https://live.netcanais.com/VIVASD/2021/01/05/08/02/27-05000.ts', offset 0, playlist 0
It works fine here. After 30 minutes I aborted the download and viewed the file. Here you can see the video streaming from youtube-dl to vlc (rather than saving to a file) with the same referer and url:
Code:youtube-dl --add-header "referer: https://esporteone.com/player/canais.php?canal=VIVASD" "https://live.netcanais.com/VIVASD/video.m3u8" -o - | "G:\Program Files\VideoLAN\VLC\vlc.exe" -
[Attachment 56634 - Click to enlarge] -
strange. for me start but after some second all stopped. here my cmd window message:
Code:D:\streaming_video\youtube-dl>youtube-dl --add-header "referer: https: //esporteone.com/player/canais.php?canal=VIVASD" "https://live.netcanais.com/VIV ASD/video.m3u8" [generic] video: Requesting header [generic] video: Downloading m3u8 information [download] Destination: video-video.mp4 ffmpeg version 2021-01-01-git-63505fc60a-essentials_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers built with gcc 10.2.0 (Rev5, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32thr eads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --e nable-libxml2 --enable-gmp --enable-lzma --enable-zlib --enable-libsrt --enable- libssh --enable-libzmq --enable-avisynth --enable-sdl2 --enable-libwebp --enable -libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-libfreetype --enable-libfribidi --enabl e-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm - -enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libgme --enable-libopenmpt --enable-libo pencore-amrwb --enable-libmp3lame --enable-libtheora --enable-libvo-amrwbenc --e nable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --ena ble-libvorbis --enable-librubberband libavutil 56. 62.100 / 56. 62.100 libavcodec 58.115.102 / 58.115.102 libavformat 58. 65.100 / 58. 65.100 libavdevice 58. 11.103 / 58. 11.103 libavfilter 7. 94.100 / 7. 94.100 libswscale 5. 8.100 / 5. 8.100 libswresample 3. 8.100 / 3. 8.100 libpostproc 55. 8.100 / 55. 8.100 [tls @ 0000000000599140] Error in the pull function. [hls @ 0000000000594800] Skip ('#EXT-X-VERSION:3') [hls @ 0000000000594800] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-01-05T16:47:19Z') [tls @ 0000000000599140] The specified session has been invalidated for some rea son. Last message repeated 1 times [hls @ 0000000000594800] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/1 6/48/54-05000.ts' for reading [hls @ 0000000000594800] Opening 'https://live.netcanais.com/VIVASD/2021/01/05/1 6/48/59-05000.ts' for reading [NULL @ 000000000324af80] non-existing SPS 0 referenced in buffering period [h264 @ 00000000035c1a00] non-existing SPS 0 referenced in buffering period Input #0, hls, from 'https://live.netcanais.com/VIVASD/video.m3u8': Duration: N/A, start: 16148.136422, bitrate: N/A Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [ SAR 1:1 DAR 16:9], 30 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Output #0, mp4, to 'file:video-video.mp4.part': Metadata: encoder : Lavf58.65.100 Stream #0:0: Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1 :1 DAR 16:9], q=2-31, 30 tbr, 90k tbn, 90k tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (HE-AAC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 0 fps=0.0 q=-1.0 size= 0kB time=00:00:00.00 bitrate=N/A speed= frame= 38 fps=0.0 q=-1.0 size= 0kB time=00:00:01.21 bitrate= 0.3kbits/ frame= 95 fps= 56 q=-1.0 size= 256kB time=00:00:03.15 bitrate= 664.2kbits/ [hls @ 0000000000594800] Skip ('#EXT-X-VERSION:3') [hls @ 0000000000594800] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-01-05T16:47:24Z')
Can anyone download it? I believe that the owner moved the link and now even using the "referer" command does not work
Code:youtube-dl --add-header "referer: https://esporteone.com/player/canais.php?canal=VIVASD" "https://live.netcanais.com/VIVASD/video.m3u8" --verbose [debug] System config: [] [debug] User config: [] [debug] Custom config: [] [debug] Command-line args: ['--add-header', 'referer: https://esporteone.com/player/canais.php?canal=VIVASD', 'https://live.netcanais.com/VIVASD/video.m3u8', '--verbose'] [debug] Adding header from command line option referer: https://esporteone.com/player/canais.php?canal=VIVASD [debug] Encodings: locale cp1252, fs utf-8, out utf-8, pref cp1252 [debug] youtube-dl version 2020.12.26 [debug] Python version 3.9.0 (CPython) - Windows-10-10.0.19041-SP0 [debug] exe versions: ffmpeg 4.3.1, ffprobe 4.3.1 [debug] Proxy map: {} [generic] video: Requesting header WARNING: Could not send HEAD request to https://live.netcanais.com/VIVASD/video.m3u8: <urlopen error [WinError 10061] No connections could be made because the target machine actively refused them> [generic] video: Downloading webpage ERROR: Unable to download webpage: <urlopen error [WinError 10061] No connections could be made because the target machine actively refused them> (caused by URLError(ConnectionRefusedError(10061, ' No connections could be made because the target machine actively refused them', None, 10061, None))) File "c:\users\uchiha\appdata\local\programs\python\python39\lib\site-packages\youtube_dl\extractor\common.py", line 632, in _request_webpage return self._downloader.urlopen(url_or_request) File "c:\users\uchiha\appdata\local\programs\python\python39\lib\site-packages\youtube_dl\YoutubeDL.py", line 2248, in urlopen return self._opener.open(req, timeout=self._socket_timeout) File "c:\users\uchiha\appdata\local\programs\python\python39\lib\urllib\request.py", line 517, in open response = self._open(req, data) File "c:\users\uchiha\appdata\local\programs\python\python39\lib\urllib\request.py", line 534, in _open result = self._call_chain(self.handle_open, protocol, protocol + File "c:\users\uchiha\appdata\local\programs\python\python39\lib\urllib\request.py", line 494, in _call_chain result = func(*args) File "c:\users\uchiha\appdata\local\programs\python\python39\lib\site-packages\youtube_dl\utils.py", line 2734, in https_open return self.do_open(functools.partial( File "c:\users\uchiha\appdata\local\programs\python\python39\lib\urllib\request.py", line 1345, in do_open raise URLError(err)
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 21:28 -
How to download streaming video from this site
By ningnong132 in forum Video Streaming DownloadingReplies: 11Last Post: 11th Dec 2020, 07:35 -
HELP with an unknown site (cannot download streaming files)
By vampire5 in forum Video Streaming DownloadingReplies: 6Last Post: 26th May 2020, 09:47 -
Download from rtlmost.hu (Hungarian streaming site)
By HunVideoMan in forum Video Streaming DownloadingReplies: 0Last Post: 3rd Mar 2020, 19:40 -
Download Streaming Site Subtitle
By bentheguitarman in forum SubtitleReplies: 4Last Post: 10th Mar 2019, 11:01
