I noticed that the BBC and Netflix mainly use EBU-TT-D subtitles. However, I can't find any subtitle editors that support this format, leading me to believe the only way to make subtitles with it is manually, which obviously isn't the case. Does anybody know the best way to make EBU-TT-D subtitles?
Never tried it, but here's what a quick search revealed some potential tools and extensions of existing tools:
EBU-TT Live Toolkit: https://github.com/ebu/ebu-tt-live-toolkit
Annotation: http://www.zeitanker.com/content/tools/zeitanker_tools/zeitanker_annotation_edit/
SubtitlingConversion Framework (SCF): https://github.com/IRT-Open-Source/scf
oXygen + EBU-TT: https://github.com/oxygenxml/ebu-tt adds EBU-TT validation and visual editing support in oXygen (https://www.oxygenxml.com/) for EBU-TT files as an oXygen framework.
FAB Subtitler STD: https://www.fab-online.com/subtitling/std/
https://pagines.uab.cat/hbb4all/sites/pagines.uab.cat.hbb4all/files/d3.4-rbb_pilot-a-e...ions_v1.00.pdf might be a good start reading,...
-> from the looks of it 'FAB Subtitler STD' seems to be the most comfortable way to edit such subtitles.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
How to make a srt file from a movie without any subtitles.
By JEG41 in forum SubtitleReplies: 16Last Post: 24th Jun 2020, 15:20 -
How to make vertical Subtitles?
By jsaechao1 in forum SubtitleReplies: 2Last Post: 12th Jun 2020, 14:07 -
Getting an EBU-TT-D xml sub with Subtitle Edit
By RegiBr in forum SubtitleReplies: 0Last Post: 25th Mar 2019, 09:26 -
Make Movable Subtitles
By imsrk48 in forum SubtitleReplies: 4Last Post: 28th Sep 2018, 03:48 -
how do you make subtitles bigger?
By zinc in forum SubtitleReplies: 20Last Post: 29th Aug 2016, 01:47
