Have found some video files that pixelate and stall on the Pi but play OK on PC (and an Andriod device).
In the filename is 'x265', but others also have this and are okay.
I believe its possible to add or upgrade the Pi software. I sometimes see a notification but so far have been unable to work out how to get/apply it.
Any help sorting this much appreciated.
RPi 3B doesn't have a hardware h.265 decoder so it has to do it with the CPU. The CPU isn't strong enough for much more than 1280x720 at 24 fps. What are you playing from? Network share? USB flash drive? USB hard drive? Bandwidth from the device could be a problem with high bitrates. And what player are you using? I usually use Kodi.
The RPi 4 has hardware h.265 decoding so it's much better for h.265 (HEVC). But right now the best deal for a media player is probably the 2020 Chromecast with Google TV. I got one recently and it plays just about everything. -
I'm playing them from a Network share. I don't think bandwidth is the problem as they play ok on an Android Device - same network. This is a lot older than the Pi but I guess different hardware? If there's nothing I can do to fix it, we'll make do as is. The player is also KODI (I think).
Thanks for the info.
What is the brand and model of this machine? dub – y/c converter
By digicube in forum Capturing and VCRReplies: 6Last Post: 7th Oct 2023, 12:39 -
firmware for samsung model drive
By datastore in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Jan 2021, 07:24 -
Sharp DV-HR300 BUT Japan BD-HDS43 model help!?!
By DaveJP in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th May 2020, 19:40 -
Is Elite Video BVP 4+ same as Model DX77?
By digicube in forum RestorationReplies: 0Last Post: 1st Aug 2019, 10:33 -
Panasonic HC-VX1 - UK/Aust model or US model?
By caix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 3rd Aug 2018, 00:55
