From what has been provided by you for me, the sthe bat script provided in post 65 works fine.
Eventhough, i see some scenes of part 1 after inter.mp4.
your quote:
You can ensure you don't lose any meaningful part by specifying overlap of say 1min. The issue with it is that you have to specify the cut time (ex: 1 hour) and this cut may occur mid-conversation.
Please say, where to correct it for overlap of 1 minute in the script posted in 65.
Had you specified this in the script, please say the line and I will change it as per your reply.
I think that the script has already has cut time of 1 hour , is it not
expecing your reply
Results 91 to 108 of 108
the second part will start at 59min if you change the line:
ffmpeg -hide_banner -ss 01:00:00 -i %%f -c copy -avoid_negative_ts make_zero -y "./out/tmp2.mp4"
to
ffmpeg -hide_banner -ss 00:59:00 -i %%f -c copy -avoid_negative_ts make_zero -y "./out/tmp2.mp4" -
Hi, thanks for immediate response.
should I change anything in inter.mp4, as it is in REM line or i could leave as it is
thanks -
REM ffmpeg -hide_banner -ss 00:09:50 -i %%f -t 100 -c copy -avoid_negative_ts make_zero "./out/inter.mp4"
If you remove REM it will create an inter.mp4 file starting before 9min50 with duration at least 100s. -
Hi, you could have just said , no change in the line.
thank you very much, inter.mp4 is a common file, i understand now
thanks for everything.
will do batch conversion and thank you once again. -
Hi, butterw, could you send the formula for a common inter.mp4 fixing A at 00:00:00:000 ms and upto a required B 00:00...........using ffmpeg, by taking input file as input.mp4 and output file as out.mp4.
so that i could take this as inter.mp4 using ffmpeg instead of avidemux.
Please say if this is correct
ffmpeg -i inputFile -vcodec copy -acodec copy -ss 00:00:00:000 -to 00:10:00:000 outputFile
Evenhough milliseconds are required for video editing , can we view the milliseconds or it is enough, if we just point to the seconds as it could be seen in avidemux.
i will use ffmpeg formula to cut and save as separate inter.mp4 common to all episodesLast edited by jraju; 23rd Jan 2021 at 22:47.
HI, BUTTERw,
when i process a single file with the change of the formula, i get the error as enclosed. please adviseLast edited by jraju; 24th Jan 2021 at 01:36.
See this post for correct ffmpeg time syntax:
https://forum.videohelp.com/threads/398507-Top10-Commands-for-Lossless-Video-manipulat...e)#post2592742
you can use seconds, no need for ms.
Note that time displayed in avidemux will likely not quite match time in ffmpeg. -
hI, BUTTERW,
Thank you so much for your clue. There is no error and within minutes, i could easily process about 15files.
Your clue on using the cut ffmpeg formula really worked.
By the By , how you could just lead me to the correct portion of your answer in the link. is there a trick. Just I click and the response is just the correct lines in the link of the answer you have given in June the previous year.
Is here a trick to exactly , load the correct line. amazing
Thanks would be a too little word of praise
thanks so much for jagabo and butterw once again.
Could you please let me know, why that error comes on the first instance. is the formation of inter.mp4 posed a problem then
this is for academic interest -
Hi, butterw,
please include code that , it just copies the file to the out folder if the input file is less than 1.00.00 hr. in the code post given by you, in post 65 -
- You can sort your folder on Length (at least on Win10) and move the files manually.
To do it via command-line you may need to use ffprobe.exe from ffmpeg to get duration in seconds, or mediainfo-cli
>ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 video.mp4
6.049000 -
Hi, I tried your formula
for a file having less than 4 hr, the result shown as 3481.091000
for more than 1hr file, the result is shown as 3766.778000
how do i intrepret this -
1 hr = 3600 seconds
Again, I don't understand why you are willing to screw up all your videos when you can buy a media player with a resume feature for US$20. -
thanks for all help in this thread
Hi, Jagabo and butterw.
I am now facing real problem.
When i run the video in my tv and stops at the video at one hour and stops and then try to fastforward up to the point, the audio gets mingled and the total video begins to play with audio not in slyncrynized manner.
The audio plays and vidoe plays but not at all in sync and i could not fastforward to the point in the video.
what is that matters and how to rectify it. -
Its not impossible that a file plays OK on your pc but not on your tv, if that is what your asking.
As jagabo pointed out getting a cheap playback device you can plug-in to your tv is likely the preferable approach here. -
Hi, Jagabo, and butterw,
butterw and your tips on using avidemux, really solved the problem .
I just select start point and end point and make two segments to save
Now no need to go to the one hour to continue watching. of course, the file number just increased a few more.
avidemux came in handy for segment saving.
Thanks for you both. After saving a segment, reset the mark of start and end points is a pointer by butterw
thanks
Are all video format converters created equal?
By ahhaa in forum ComputerReplies: 15Last Post: 2nd Nov 2020, 16:18 -
Video Split Does not split at exact point
By Nothingissimple in forum EditingReplies: 2Last Post: 2nd Oct 2020, 20:58 -
is there any any software to split video base on scene?
By ujang in forum Newbie / General discussionsReplies: 45Last Post: 15th Aug 2018, 11:05 -
Software for windows besides ffmpeg to split multiple videos?
By carlrandall72 in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2018, 08:43 -
Will a Sony DVCAM DSR-20MDP play 60 minutes on a tape recorded 60 minutes?
By snufsis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jun 2017, 20:00
