i was trying to encode avi files but it says it cannot be supported
it encoded similar files
by the way the avi files are 15 mb
Probably TMPG can not handle that large file.
Split the avi to several small files. http://www.vcdhelp.com/virtualdubedit.htm
Chose as output file names file00.avi, file01.avi, file02.avi, etc. etc.
Then open the first segment (file00.avi) in VirtualDub and frameserve to TMPG (all segments will get loaded automaticly).
http://www.vcdhelp.com/convert.htm#frameserve
Also decompress the audio to wav if it is a compressed format.
In TMPG you may play with the priorities of the VFAPI plugins.
In addition I recommend to install ReadAVS.dll, that is used as VirtualDub/Avisynth file reader VFAPI plugin.
http://forum.vcdhelp.com/search.php -
Am I missing something here ? He says AVI is 15mb That is a very small file ?
Sounds like you need to install the codec needed to compress/decompress this AVIi was trying to encode avi files but it says it cannot be supported
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
Hi DEf Encoding with TMPGEnc and subs
By millzy in forum Newbie / General discussionsReplies: 0Last Post: 7th Oct 2008, 11:25 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
