Hello
I'm trying to batch extract subtitles from .mkv files and I found MKVCleaver to successfully do that but I cannot find a way to name the extracting .srts to be exactly as the filenames of the videos.
When I try this in the Custom Filename Form
I get this AutoIT error
Also tried with these brackets [] as mentioned here
but same error.
What am I doing wrong here?
[edit] Meanwhile, I managed to find a way to do the batch extracting with ffmpeg and powershell with the following code
Code:foreach($file in Get-ChildItem $(pwd)) { ffmpeg -i $file -map 0:s:0 $(echo $file | %{$_ -replace ".mkv",".srt"}) }
Apparently you found a workaround that might be more convenient than the initially intended method, but shouldn't the extension be included in the naming pattern, i.e. « <filename>.srt » ? Arguably the embedded tips are quite confusing (in particular, I don't know how to interpret the second-to-last line in the last screenshot).
Yeah, confusing to me as well. I tried adding the extension, I still get errors. Did you try for yourself?
Aren't there more detailed explanations in the “help file” ? And what does the scouter say about it ? -
I found the developers website. This page might help: Sheck's Software: Custom Filename Examples
Unable to use MKVCleaver
By polferis in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jul 2018, 00:03 -
Aegisub - batch support? or better way to batch process/edit subtitles?
By Restricted in forum SubtitleReplies: 7Last Post: 5th Sep 2017, 22:10 -
Question/Help Regarding Extracting Subtitles
By truegalbklyn in forum SubtitleReplies: 1Last Post: 15th Sep 2016, 11:40 -
Cannot get MKVCleaver to extract chapters
By NDMMackay in forum EditingReplies: 1Last Post: 21st Feb 2016, 12:56
