I like to rip my movies to a video server. I have an i5, so it is fine for 1080p stuff...specifically I will reencode movies that have forced subs to "burn" them into the video when needed (via Handbrake and via software encoding). This is problematic for x265 and 4K rips though...it just takes too long, so I use nvenc. I was wondering, do newer graphic cards have "better" video encoding characteristics for this type of encoding? That is, has nvenc changed over the years to make it better? I currently have an older EVGA GTX 1050Ti and it seems to do a nice job with nvenc and x265 hardware encoding in Handbrake. I'm just wondering if a new GPU upgrade will only decrease render time, or would it make the encode itself better as well via a "newer" nvenc.
If a newer card would be beneficial overall, what would be a good non-super-duper-high-end one?
Thx
Results 1 to 14 of 14
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
It's not impossible to buy an rtx,just really expensive if you buy off ebay.I'm waiting till evga sends me an email when they get supplies in.
Yes, definitely. HW and algorithms have improved.
An obvious difference between 1050ti (Pascal) and newer cards (Turing, Ampere) is that the newer cards support B-frames for HEVC (H.265), while the 1050ti supports B-Frames for AVC (H.264) only.
More here:
https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new
Also, the algorithms seem to have improved with SDK10.
http://developer.download.nvidia.com/video/gputechconf/gtc/2020/presentations/s21337-n...l-flow-sdk.pdf
https://docs.nvidia.com/video-technologies/video-codec-sdk/nvenc-video-encoder-api-pro...ame-phencoding
Recently jdobbs did exhaustive comparison tests for x264 vs NVEnc with interesting and surprising findings for HD AVC encoding with his GTX1660 (Turing)
https://forum.doom9.org/showpost.php?p=1929974&postcount=30232
https://forum.doom9.org/showpost.php?p=1930266&postcount=30244
In my own tests with my older 1050ti I couldn't quite match his results. The file size in my tests was 15....30% bigger for NVEnc for similar PSNR or SSIM compared to CPU x264 for my 1050ti. So I conclude the newer cards perform better wrt speed AND quality. Nevertheless I am quite happy with the quality vs filesize I get with the 1050ti for HD AVC encodes. -
RTX encoder isn't improved over previous gen anyways. RTX 3090 has the same encoder as e.g. GTX 1660.
https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new -
Hmmm....so does this mean that my 1050Ti is not that far behind? I usually just feed it a ton of bitrate, as I am not that interested in saving much space. Again I am really only interested in "burning" forced subs into the video file with maximum quality. Perhaps the 1050Ti with high bitrates is enough?
Again, I do not need a $1000 card upgrade, especially if the only real differences can be accounted for by added bitrate.
Thanks for the responses so far!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Interesting question. It seems like if I am giving enough bitrate, then it hardly matters what card I use for nvenc encoding. So I guess the interest lies with maybe getting something quicker or, perhaps down the line, compressing a bit.
Accordingly, the conclusion would be that if I am utilizing enough bitrate for these "forced sub burned encodes" to get a resulting file that is similar in size to the original, then the GPU used really does not make a difference. It is only if I wanted something half the size that a more modern card may be of benefit.
Does this sound correct? Happy New Year!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Means that the rtx series are not any better for encoding than previous versions.
Thank you all for the comments. I'll stick with what I have since I am not interested in really reducing file sizes.
Date time change program
By Budman1 in forum Video ConversionReplies: 24Last Post: 8th May 2023, 21:29 -
Change Time Stamp on .mp4 video
By threehappypenguins in forum Newbie / General discussionsReplies: 51Last Post: 24th Apr 2021, 19:05 -
change the time before sleeping
By Jomapil in forum ComputerReplies: 4Last Post: 8th May 2018, 05:31 -
line duration - how to change the time permanently ?
By IDAN in forum SubtitleReplies: 1Last Post: 29th Nov 2017, 06:23 -
[Solved] How to change title start time with DVDRemake Pro 3.6.3?
By EmmB in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2017, 14:53
). But if you are currently happy (as you said) I don't really see any need to upgrade.
