  1. please help!!!
    When I use DVDDecrypter to copy a dvd one of the chapters comes out in french. Why is that? I did it over again and the same thing happened again on the same chapter. This is only my second time doing this and I used the guide posted on this site. Please tell a newbie what to do to fix this problem
    Speedy
    amd athlon 1700
    256 mb ddr ram
    windows me
    40 gig wd 7200 hd
  2. sorry guys i ment one of the vob files are in french
    please help
    speedy
  3. wut u mean one of the vob files are in french? you mean the audio is in french when u try to play the vob file? if this is the case, don't worry about it, playing the vob files directly doesn't mean very much
    all you need to do is extract the right audio file you want w/ dvd2avi, then you don't have to worry about the french (language...i mean)
  4. thanks guys your info helped a lot!!!
    speedy :D
