~Has anyone had any audio problems when converting a divx film to vcd/svcd with videopack. I have tried on a number occasions to drop a divx file to be converted in one simple step, and when completed the film video plays but there is no audio.Does anyone know if you have to split the audio and convert first and then add it back to the video? I was hoping there was an easy way to still use videopack and avoid stripping the audio and then adding it back to an avi file and then converting that avi file to vcd. Any insight to this enigma would be greatly appreciated.
~~Thanks,
newbie to videopack5.1
Video Pack 5, like all "Authoring" programs are no good at converting AVI's to Mpeg's.
Use TMPGEnc to convert before dropping them into Video Pack.
Also, you have no way of knowing if the AVI has any bad frames, if you don't use a scanner like Vdub to check them.
You could get 80% through a conversion, only to have a crash.
I always use Video Pack 5.1 to make the VCD's, but first I would have used Vdub to check them, then TMPGEnc to convert them. This is the fastest method with the less errors. 90% of the time, the audio is just fine, and does not need to be saved out.
DivX conversion
By didikai in forum Video ConversionReplies: 2Last Post: 27th Nov 2011, 11:23 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 02:22 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 13:41 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 04:13
