I'd like to find a device that convert hdmi to Y/C (if i can use it directly from sony vegas timeline that's a big plus)
My goal is to record videos on vhs tape.This is for my own entertainment, so my budget is close to zero.
I'm not certain but if i buy one of the many converters i see on amazon & co, i foresee problems like screen resolutions and interlacing not fully set and 60hz/50hz problems aswell.
In short that converter will have to downscale to 576i or 480i correctly
Thanks guys
I went through this rabbit hole before and I can save you a lot of headache, The only solution that works with no artifacts such interlacing problems, tearing, frame drop ...etc is this:
https://forum.videohelp.com/threads/392370-BM-Intensity-Shuttle-Owners-Feedback-Needed#post2551583
You can go buy all the HDMI adapters you can find as I did but that's what worked best.
any remotely decent video players out there ?
By easytools in forum Newbie / General discussionsReplies: 5Last Post: 30th Nov 2020, 10:32 -
S-VHS + HDMI upscaler + HDMI capture?
By Jupit0r in forum Capturing and VCRReplies: 2Last Post: 22nd Aug 2020, 03:00 -
HDMI to Component Converter
By tconstan in forum Video ConversionReplies: 6Last Post: 30th Dec 2019, 17:53 -
By cottage in forum Newbie / General discussionsReplies: 5Last Post: 24th Jun 2019, 17:38 -
1080psf25 to 1080p25 HDMI converter
By vin97 in forum Capturing and VCRReplies: 0Last Post: 3rd Aug 2017, 14:58
