You're right, I guess I have nothing to lose and I should at least try it. Might be an easy solution.
By the way, my family owned a top loaded VCR we bought around 1980 and that VCR bypassed Macrovision. I believe it was Telefunken VR-440. It was funny because we used that VCR throughout the whole 80s and half of the 90s to copy probably hundreds of tapes and we weren't even aware of copy protections on tapes. It was not until that Telefunken finally broke down after more than 15 years of use that we learned about Macrovision, when we bought a new VCR. lol
Results 31 to 47 of 47
What the OP needed or still could use maybe, is a "Video Stabilizer " which is a simple box that neutralizes MV. RCA composite in and RCA composite out. Then search out whatever, or the best capture device that is within budget. A two-box approach rather than one box that does it all.
I copied a boatload of old VHS concert tapes in the 2002 - 2010 era or PC capturing, and burned them to DVDs. All titles that never appeared on DVD or even LD. I ended up buying a DataVaideo TBC-1000, but kept the stabilizer on hand anyway. I wonder what they go for now? I think I paid around $25 in 1989.
There it is, from Canada, $25 USD
https://www.ebay.com/itm/133818574898?epid=1753061543&hash=item1f28356832:g:b0AAAOSw2Odf-JcY -
Sorry meant to reply to this topic some time ago just forgot all about it.
I still have a Plextor ConvertX PX-M402U something I used a lot in my time and this bypassed every single tape I had that was mv protected, only downfall was the windvd creator 2 software it needed a certain patch that fixed the issue of it shutting down when recording. I would still use this device if I could find the patch but it's no good without it, I tried the ulead software that come with the USA version but that was just as bad. -
No.
That ancient 1980s device was often enough to fool another VCR into thinking anti-copy was not present, for the purpose of copying VHS to another VHS. But the signal was still dirty. When you capture/digitize VHS tapes, the input signal must be clean, otherwise all sorts of problems present. Some errors are just ugly to view, others prevent capturing entirely. It's not a TBC, or even a type of TBC.
Many have tried this box, some claim to have success (rarely actually the case, especially when their capture results are seen), but most have issues. Again, because it's not a TBC.
Horrible capture software. Use VirtualDub, capture lossless. (If you must have MPEG capture, get a MPEG hardware card. Or ATI AIW for use with WinXP only.)Want my help? Ask here! (not via PM!)
Yep I know that mate I did try VirtualDub but went over to using Lite-on machines instead I haven't used the device in years the Lite-ons are good enough for me.Horrible capture software. Use VirtualDub, capture lossless. (If you must have MPEG capture, get a MPEG hardware card. Or ATI AIW for use with WinXP only.)
What do you mean?
Dazzle DVC 100 reports that video is protected with Macrovision by setting a flag, but does not disable the video unlike the AverMedia CE310B. Pinnacle's own software reads the flag and refuses to capture, but VirtualDub has no problems with it. I captured from several tapes from Paramount, Warner Brothers and and MGM - purely as a scientific experiment, of course. No problems. I made a video about Dazzle devices, if anyone cares for some light entertainment. I suppose DVC 101, 103 and 107 work exactly the same as the 100, because these are essentially the same devices. They have been available since 2006, but they still can be found on eBay, even as NIB.
BTW, does anyone know what exactly is being sold now by Pinnacle? Is it DVC 100 or something else? Other websites show device name as DVCPTENAM. The Amazon page says that it works with only 64-bit versions of Windows, which is weird, because there are 32-bit drivers for DVC 100. I did not care to buy a new unit from Amazon just to check the model number, but maybe someone have bought one?
Here is a shot from Doc Hollywood.
I doubt the currently sold dazzle is the same as the DVC 100 at least, as that used a Philips/Trident/NXP SAA7113 IC which as far as I know is no longer produced. I'm not sure if the USB IC is either.
The driver/patch I could find suggests it's some empia chip based product still, though I'm not sure if it is or it just contained an extra driver or smth, but no idea which. -
Sorry if my question is totally stupid, but is there any sort of copy protection, either Macrovision or other, which were used on blank VHSs? I mean could it happen that someone buys some blank VHSs, use them to record his home videos on it, and he is trapped, because all those analouge data cannot be digitalized?
The background is that I ran out of ideas why a usb videograbber can “show” the video content of my only CVC used years ago in my camera, while at the same time cannot do with that of any of my VHSs used years ago to be copied recordings from this CVC onto. https://forum.videohelp.com/threads/401457-AT-MY-WITS-END!!-VHS-capture-device/page2#post2675373
Thus I thought maybe there are some false protection on my VHSs, which makes impossible to digitalize their video content. -
No domestic VHS creates true copy-protection but if the signal is weak then there could be 'false-macrovision'
I have also replied to the other topic. -
Well then maybe I should create new, fresh content onto one of the VHSs and see whether it appears through the video grabber.
If you can. But if you no longer have analogue broadcasting or a dvd-player or another device that can support analogue out recodings are no longer possible.
My idea was to shot a short video with this old camera (so I have to literally take it out from the dustbin where I yesterday threw it into), and repeat the copy process from the camera to a never-used VHS which I still have.
Probably someone screwed up the recordings from the VHS-C (again, not CVC) to the full size VHS cassette by not plugging in the composite connector in the right plug and manage to plug in the audio cable/cables in their right plugs, It happened quite a lot back in the day. But if you have the original VHS-C tapes why would you want to digitize the copies?
“Probably someone screwed up the recordings from the VHS-C (again, not CVC) to the full size VHS cassette by not plugging in the composite connector in the right plug and manage to plug in the audio cable/cables in their right plugs, It happened quite a lot back in the day. “
I guess you had written it before checking the other thread with the details. I was the one who could have screwed up the recordings, but if the video recordings on VHSs are properly playable back on a TV, then I guess it confirms I could not use wrong plug. And it is so simple: one video plug, one audio, both on my camcorder, and in the front of my VCR.
“But if you have the original VHS-C tapes why would you want to digitize the copies?”
The answer is in the other thread. I used 2 VHS-c of 30 minutes to shot videos and finally I had a content of 16 hours “archived” on 4 VHSs of 240 minutes in SP mode + 2VHSs of 240 mins in LP mode as secondary/backup copies.
Best VHS to Digital Product for Mac in 2020
By paulmolive in forum MacReplies: 17Last Post: 29th Mar 2021, 05:25 -
10bit BT.2020 HDR content to 10Bit BT.2020 WITHOUT HDR metadata
By wmplib in forum Video ConversionReplies: 3Last Post: 10th Apr 2020, 08:44 -
Cheap USB Dongle / Hi8 to Mac / Badly distorted any point in trying to fix?
By mahu1982 in forum RestorationReplies: 2Last Post: 31st Oct 2019, 20:43 -
What file format does USB sticks be formatted to play on the cheap entry
By oduodui in forum Newbie / General discussionsReplies: 11Last Post: 17th Apr 2018, 07:04 -
Solved - How to connect Windows (by USB) to cheap LG Android device
By jimdagys in forum ComputerReplies: 5Last Post: 11th Feb 2016, 21:37
