Hi folks,
I have this track that peaks at -0.1dB: https://drive.google.com/file/d/1cTtxP1OMrNtEqq3VBeq1maDdcZBdovas/view?usp=sharing
I add it to Vegas Movie Studio Premium 17, remove all track FX, don't change any other settings and render a new wav: https://drive.google.com/file/d/1414qUJXNhlRoeALeUMYxUMqq2qfsNXvk/view?usp=sharing
The track gain is 1.0, volume is 0.0, master fader is 0.0, no FX on master.
The problem is that the new wav is louder - it peaks at 0.2dB. Do you know why?
Mike.
vegas pro says your original wav peaks clip at 0.3dB over.
[Attachment 56460 - Click to enlarge]Last edited by aedipuss; 26th Dec 2020 at 19:09.
You converted 44.1 KHz 24 bit samples to 48 KHz 16 bit samples. That will cause small changes in peaks and troughs.
Thank you jagabo, I've rendered the original audio in 48K and it worked!
aedipuss, thanks for checking! I think the reason it works for you is because your default setting is 44K.
Vegas Movie Studio and interlaced content
By smartel in forum Newbie / General discussionsReplies: 45Last Post: 8th May 2019, 20:09 -
Converting AVI From Vegas Movie Studio to GIF
By pone44 in forum EditingReplies: 10Last Post: 18th Sep 2018, 08:55 -
Vegas Movie Studio vs Adobe Premiere Elements
By rfe777 in forum EditingReplies: 12Last Post: 6th Dec 2017, 10:40 -
Vegas Movie studio 14 V's Cyberlink Power director 14
By justcurious in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2017, 12:10 -
control volume increases during "exciting" parts of movies?
By marknoo in forum AudioReplies: 6Last Post: 19th Apr 2016, 18:22
