Results 1 to 21 of 21
    Dec 2020
    Malaysia
    need some help how to download movies from this website
    monomax.me
    login : joedecruz@gmail.com
    temp pass : 12345678a
    i tried F12 and copy link . but the video or link won't play on other tab. it must be click and open on the same tab. i did try use stream recorder but once click capture the video will auto close page
    [Attachment 56435 - Click to enlarge]
    i tried using invidownloader and getting errors after download
    [Attachment 56438 - Click to enlarge]
    [Attachment 56439 - Click to enlarge]
    [Attachment 56440 - Click to enlarge]
    Dec 2020
    Malaysia
    Originally Posted by LZAA View Post
    Url?
    url
    www.monomax.me
    Dec 2020
    Malaysia
    Originally Posted by marcelo_bor View Post
    hi is this mean you already downloaded it. can you teach me how to download it using what software or code or search . thanks
    currently downloading your file.
  4. www.monomax.me is generic url.
    write specific video link that you want to download...
    Dec 2020
    Malaysia
    [Attachment 56523 - Click to enlarge]
    hey hey . im sorry im still stuck at searching for the key .
    i manage to download the video and audio file seperately .
    used to get KID key . and decrypt it using mp4decrypt but it still wont work . i think i got the wrong key . can you help me thru it. thanks alot
    not sure why i can't private msg you anymore. keep getting error form submitting
    Sep 2021
    Los Angeles
    Well, didn’t you download them, 'cause the screenshots show you installed everything. I usually use utorrent to install any programs, games, or movies, I had no problem downloading all of this. Try another torrent client. Enter the pirate bay, download the movie from there, and then install it in torrent clients. Or maybe I just didn’t understand the question.
  7. Originally Posted by Bvgary View Post
    I download all movies with pirate bay
  8. How can I download this episodes (chinese language, 1080p)?
    https://www.monomax.me/title/104244-lighter-and-princess.html
  9. Originally Posted by mariellbergh View Post
    https://we.tl/t-RubK2nIuNF
    --key db078ef435e352d78ce6dae24a34d055:e4b76110a0259cde551cbfc55c511688 --key e92beb4b2fa152e591041a2eef1c15be:1747a0b7f1ebf07f36eb140a88709b86 --key 2120dca271d25c5f8d7b151dc32098e1:8524487d18357f461d66454e9116393f --key a4eabd9bef5254c4ac3422ab0f921c1a:7a8969654ec79e2c6a0a48b37d0cf1f0 --key a135e71129bf53239cfee944a40f024c:1482738b65613436e3f0d87b3ce11669
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  10. Originally Posted by [ss]vegeta View Post
    Hi, thank you very much for answering my question here (https://forum.videohelp.com/threads/400066-need-some-help-how-to-download-movies-from-this-website).
    Could you explain to me step by step how I can download the rest of the episodes of the series "Lighter and Princess"?
    I would like 1080p quality in the original Chinese language with the .ts extension.
    Using IDM Downloader, I see e.g. only these links:
    https://stream-cd.monomax.me/streams/20221219/g1gbC8ZM1af8E2a3/HsUPvV2NCbD11v5Q_h264_1920w_28.mp4
    https://stream-cd.monomax.me/streams/20221219/g1gbC8ZM1af8E2a3/FFFXYx3g12Cl6IlU_libfdk_aac_2_35.mp4
    Regards and thanks in advance for your answer.
  11. Code:
    yt-dlp --allow-u https://stream-cd.monomax.me/streams/20221219/g1gbC8ZM1af8E2a3/BMfDxgJKwB2EoAG4.mpd
    Decrypt with tke keys found by [ss]vegeta
    Video
     mp4decrypt.exe --key db078ef435e352d78ce6dae24a34d055:e4b76110a0259cde551cbfc55c511688 --key e92beb4b2fa152e591041a2eef1c15be:1747a0b7f1ebf07f36eb140a88709b86 --key 2120dca271d25c5f8d7b151dc32098e1:8524487d18357f461d66454e9116393f --key a4eabd9bef5254c4ac3422ab0f921c1a:7a8969654ec79e2c6a0a48b37d0cf1f0 --key a135e71129bf53239cfee944a40f024c:1482738b65613436e3f0d87b3ce11669 video.mp4 output.mp4
    Audio
    mp4decrypt.exe --key db078ef435e352d78ce6dae24a34d055:e4b76110a0259cde551cbfc55c511688 --key e92beb4b2fa152e591041a2eef1c15be:1747a0b7f1ebf07f36eb140a88709b86 --key 2120dca271d25c5f8d7b151dc32098e1:8524487d18357f461d66454e9116393f --key a4eabd9bef5254c4ac3422ab0f921c1a:7a8969654ec79e2c6a0a48b37d0cf1f0 --key a135e71129bf53239cfee944a40f024c:1482738b65613436e3f0d87b3ce11669 audio.m4a outputaudio.m4a
    merge the 2 files with ffmpeg
    ffmpeg -i output.mp4 -i outputaudio.m4a -c copy final.mp4
    or just one command line with N_m3u8DL-RE
    N_m3u8DL-RE.exe --key db078ef435e352d78ce6dae24a34d055:e4b76110a0259cde551cbfc55c511688 --key e92beb4b2fa152e591041a2eef1c15be:1747a0b7f1ebf07f36eb140a88709b86 --key 2120dca271d25c5f8d7b151dc32098e1:8524487d18357f461d66454e9116393f --key a4eabd9bef5254c4ac3422ab0f921c1a:7a8969654ec79e2c6a0a48b37d0cf1f0 --key a135e71129bf53239cfee944a40f024c:1482738b65613436e3f0d87b3ce11669 https://stream-cd.monomax.me/streams/20221219/g1gbC8ZM1af8E2a3/BMfDxgJKwB2EoAG4.mpd -M format=mp4
  12. Originally Posted by cedric8528 View Post
    Video
    Audio
    System nie może znaleźć komunikatu dla numeru komunikatu 0x2350 w pliku komunika
    tów dla Application.
    Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone.
    E:\FFmpeg 2>yt-dlp.exe --allow-u https://stream-cd.monomax.me/streams/20221219/g
    File "Lib\site-packages\PyInstaller\hooks\rthooks\pyi_rth_multipr ocessing.py",
    line 12, in <module>
    File "PyInstaller\loader\pyimod02_importers.py", line 493, in exec_module
    File "multiprocessing\__init__.py", line 16, in <module>
    File "multiprocessing\context.py", line 6, in <module>
    File "multiprocessing\reduction.py", line 16, in <module>
    File "socket.py", line 49, in <module>
    ImportError: DLL load failed while importing _socket: Parametr jest niepoprawny.
    [4820] Failed to execute script 'pyi_rth_multiprocessing' due to unhandled excep
    tion!
    E:\FFmpeg 2>
  13. The keys for the next Episodes
    Ep 2
    06cc0147b76e508da9fe7740e6a393ab:031bbf052f755831705865dbc15c8dfc
    4c50727f46625192861a590a2f446fad:23a58428a886bd6e09ebade751061e36
    b94f1dfc27d95868ac52cf2c5c1aa263:64a636c5276dc7317b9dc3ad59b5b2d3
    842779f480f85c60b37b30e627f57e89:ff0ed2603e302ab70187294b0b321cd0
    d79e90a3c21a52e2936521f31465ee75:6bfab0e088ece3fb6176b7dea94e0f28
    Ep 3
    8f983c387a125894870c5e360e46449c:b85130fd5269e4910dc96d920dd7766e
    81b709b9c1455101a90489ee52a8e571:661e095e6ed73c22cfbc947fb74d56eb
    9834656a79525a6685de8d9bf2d19376:df21abc28440fe55cc3188caccfa04a8
    b255f67f8c4f5b37a2775a57f22e2296:f75d01e7520c4db101e9ddb250966d02
    520f06c5e14b5bfaa80e2ec6768cdd16:006577d4edccb8313c5eb19f04dac2d3
    Ep 4
    96bc91ed9aa453d6bbd9e36c6309b6a8:f67c41d79d36361ced778d195673fea9
    2799f774a41e58f08ffb3c84f73c580a:419ed5ef711341d86a90e697464362e3
    55bc5a2681635c3584819f06b8166bee:997d126f3903af89750dc0784c314568
    d1c0bf7061c756cc9b73d4664504a1b6:cd6fbe458025d1e0969be16b15882dc9
    7a8ca8d44b8d5b9fa485936da5d5390a:01595502daca987879fbe76f3418e367
    Ep5
        bafaf58fdb8c5053b8c9a769ee48ffe2:0ac69e290c9899527844c2177e26c3cf
        fdded09c42685a3da9c67b506a2fb69b:8987b86ffd6feabba5ea477ccc3461c0
        2c5d5097465c502284c8f647e760fe0c:bd0d821300c20ee3b0bba437c8e81ec8
        fc7f9e88530a597cba1ad77fd06fa92c:a9bea59294c167449495b281555adc51
        5fa17b488d865171afb58d2a63fa7ed0:efa8ebc8c2cbb738f6a7641afc2b8ba9
    Ep6
    376cfbf346eb5483aa1cb442c28f5cdb:cee0d5ee67b07da5dfbf252f34aef933
    0af698ef1b9e51599278ca813de6bb17:0ac14dc8abf1df2095c17d8ddab105f4
    3339eb7f7d3452739f4927a771d47067:8b05f5f3bf8251df0a0909aa468e42e4
    a7578491193156eba7ef54f24ca4264d:c1919c4007fb7faca0f5a1feee907490
    264dcd1195bf5826b448b372b367aee9:8cf971fad385a2eb6053d3a00c7379c7
    Ep7
    a1d1fbfc58785407a3f510a7e56cb7cf:f94f4ee383504078938e2ac5cd455bb6
    2b48afe0912f58f39f08bbdd0c3e212c:0c07f2b5c23c58c5573d290be22b0301
    7f0c2bec323153f888b3da226ce3e39d:1187f0c1240321a57813f36a46091da3
    0e2eb221bf5d5bdfbe63f3d55f6fd669:fd45f9bfdf8381bb0224b6458a1b4a43
    bf94c7c0ddd756be8af879f65b091573:395dffce5bc69cf08b7e3247f6b6efa6
    You can use this site to get keys.... https://cdrm-project.com/
    [Attachment 68324 - Click to enlarge]
    You just need two things:
    PSSH and License Url
    I let you search by yourself on the forum to get these 2 informations.
  14. all right. only 2 useless consideration:
    1) when you put mpd or other link in yt-dlp or N_m3u8DL-RE is better put the link into double quote like "https://mpd_link"
    sometime with long mpd or unknow character we have some error. tip only, not strictly necessary, but recommended
    2) when you have multi key (like the link above) put all keys only on new txt file. rename as key.txt and run:
    N_m3u8DL-RE -M format=mp4 --key-text-file key.txt "https://_mpd" --save-name video_bla_bla_bla
  15. What exactly does multi-key mean? Are there several parts, each one with a different key?
  16. Originally Posted by Quint View Post
    Nah, it's just for when you receive many kid:keys and you are lazy enough to check which kid matches the resolution you downloaded.
    You do a little brute-force of the sort.
    click click2
  17. look post#15 by cedric. every ep have multi key (5 for each ep)
    one only is for video, and one only for audio
    but you get key for all res available, so 5 keys
    with mp4decrypt you need to use all keys. you don't know what is necessary for your resolution
    so put all key on txt file and rename as key.txt
    N_m3u8DL-RE (with mp3decrypt on same folder) use the right key necessary to decrypt your resolution
  18. Ah, ok. Got it. Thanks!
  19. How can I extract a link with .mpd from a page source?
