guys plz how i can do Frame rate mode : Constant like this
Video
Format settings, Reference frames : 4 frames
Codec ID : avc1
After encode in Staxrip 1.7.0.0 Found Frame rate mode : Variable
Codec ID : avc1
Duration : 8 s 340 ms
Bit rate : 1 200 kb/s
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 (23976/1000) FPS
Minimum frame rate : 23.976 FPS
Maximum frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 03:50 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01 -
Variable frame rate into constant frame rate without re-encoding
By DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 12:05 -
Encoding using Constant Rate Frame (CRF)
By fatammag in forum Video ConversionReplies: 5Last Post: 9th Jun 2016, 10:08 -
Should I use Constant Frame Rate encoding?
By Downgraded286 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Mar 2016, 02:37
