Hi guys.
Need help with mpd download
mpd link: https://vod-krakowplay.app.insysgo.pl/assets/2020_11_24_KFG_Building_Bridges-aws-55c5a...dash/index.mpd
referer: https://playkrakow.com/vods/vod.290
i got l3 mpd key with a plugin (d481f1ac1c81960ccf2aca72401a6da5 (KID=3d6f3d0cd57b466fbbbcd10e13640864)) and what i tried to do was download init file + all the segments (01-36), merged them to one file and tried to decrypt with a command below
ffmpeg output looks like this:Code:ffmpeg -decryption_key d481f1ac1c81960ccf2aca72401a6da5 -i out.mp4 decrypted.mp4
any clues what am i doing wrong ?Code:ffmpeg version 4.2.4-1ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9 (Ubuntu 9.3.0-10ubuntu2) configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared libavutil 56. 31.100 / 56. 31.100 libavcodec 58. 54.100 / 58. 54.100 libavformat 58. 29.100 / 58. 29.100 libavdevice 58. 8.100 / 58. 8.100 libavfilter 7. 57.100 / 7. 57.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 5.100 / 5. 5.100 libswresample 3. 5.100 / 3. 5.100 libpostproc 55. 5.100 / 55. 5.100 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55e5c2f21340] Found duplicated MOOV Atom. Skipped it [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55e5c2f21340] Incorrect number of samples in encryption info [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55e5c2f21340] Could not find codec parameters for stream 0 (Video: h264 (avc1 / 0x31637661), none, 1280x720, 2683 kb/s): unspecified pixel forma Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'out.mp4': Metadata: creation_time : 2020-12-06T07:30:52.000000Z major_brand : isom minor_version : 1 compatible_brands: isomavc1dash Duration: 00:04:44.28, bitrate: 2696 kb/s Stream #0:0(und): Video: h264 (avc1 / 0x31637661), none, 1280x720, 2683 kb/s, 25 fps, 90k tbr, 90k tbn, 180k tbc (default) Metadata: creation_time : 2020-12-06T07:30:52.000000Z handler_name : ETI ISO Video Media Handler encoder : Elemental H.264 Side data: unknown side data type 24 (123699 bytes) Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Press [q] to stop, [?] for help [mov,mp4,m4a,3gp,3g2,mj2 @ 0x55e5c2f21340] Incorrect number of samples in encryption info out.mp4: Invalid data found when processing input Cannot determine format of input stream 0:0 after EOF Error marking filters as finished Conversion failed!
ok i guess i figured it out. each separate file needs to be merged with init file and decrypted before merging segments to one big file.
How To Download from COM (segmented .mp4)
By jilboobseksi in forum Video Streaming DownloadingReplies: 7Last Post: 11th Jun 2020, 19:56 -
download mp4 from hls.js
By farafero21 in forum Video Streaming DownloadingReplies: 9Last Post: 1st Feb 2020, 08:54 -
Mp4 download and decrypt ?
By hizlitv in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Jul 2019, 12:34 -
Can I download my tennis tv match streams as MP4's?
By R.STEED in forum Video Streaming DownloadingReplies: 4Last Post: 31st Jan 2019, 09:35 -
help to download mp4 link
By perwann in forum Video Streaming DownloadingReplies: 2Last Post: 24th Aug 2016, 15:41
