Whether I import a video or use the dynamic link the footage shift one frame back. The first frame is the second and the last frame is gone. Has anyone encountered this issue?
That is often the result of interlaced footage being improperly interpreted. Right Click on your source and choose "interpret footage>main." Try different settings under Field and Pulldown see if anything works. Tip: if you place the footage into a comp before doing this, you will see the results immediately.
problems skipping forward / backward on an mkv file.
By rotchild in forum Newbie / General discussionsReplies: 7Last Post: 13th Oct 2020, 17:00 -
Best way to compare two videos (original and converted) for frame shift?
By Bencuri in forum Video ConversionReplies: 4Last Post: 27th Aug 2018, 22:06 -
Frame Rate, Bitrates ans Frame by frame comparison
By novreis in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2018, 18:40 -
download off of dailymotion title screen letters are backward
By RBCC in forum EditingReplies: 2Last Post: 16th Dec 2017, 22:12 -
Seeking/jumping forward/backward in a video
By [ss]vegeta in forum Software PlayingReplies: 8Last Post: 6th Aug 2017, 10:21
