Question 1 - If I'm not worried about disk space and don't need to deinterlace/detelecine the DVD is there any reason I shouldn't use MakeMKV on DVDs I intend to put on my Plex server? Should I worry about re-encoding at all in this scenario?
Question 2 - I was previously using MakeMKV and then re-encoding with ffmpeg through Avisynth but was informed I shouldn't encode an MKV (since it can cause audio and video to be out of sync) and should instead use DGIndex which left me wondering if MKV files made with MakeMKV have an inherent possibility of having "out of sync issues" or if that only happened when encoding from the MKV file instead of using DGIndex? Can anyone please provide clarification on this workflow? I'm still trying to wrap my head around this.
Q1 Only reason I can think of is wanting to use use full disc menus. If you don't worry about diskspace, don't re-encode then. Best way to stay at your source quality.
Q2 I hardly doubt that mkv, which is only the container, is prone to AV sync issues. I never had these with mkv because of mkv. -
Never had makemkv itself cause sync issues but when recoding the audio I sometimes have to put -200ms in the audio sync box of mkvtoolnix to get sync. It's my doing as I'm demuxing everything then remuxing.
if all else fails read the manual -
deleted
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Using MakeMKV to rip DVDs, I have a few questions
By CursedLemon in forum Video ConversionReplies: 4Last Post: 29th Oct 2020, 12:45 -
Need help getting recovered DVDs to play correctly and load in Makemkv
By wjbraden in forum Newbie / General discussionsReplies: 7Last Post: 25th Aug 2020, 02:59 -
How to build a portable Plex/NAS server and populate it with my old DVDs
By nolaguy in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2018, 01:07 -
Plex Media Server - Won't Scrape Metadata
By Chopmeister in forum Media Center PC / MediaCentersReplies: 1Last Post: 26th Sep 2016, 04:20 -
16:9 dvds convert to MKV have black side bars in PLEX?
By Denvers Dawgs in forum Video ConversionReplies: 2Last Post: 18th Jun 2016, 19:21
