I have a question I hope someone here can answer. I bought this software and have a top menu with 4 tracks setup. I saw how you can add background audio that loops until a track is chosen to be played but I can only get very very short audio clips to loop. Is it possible to get longer audio clips say 1-2 minutes in length to do what I am asking? Support leaves much to be desired....
Under the Motion Menu Tab of the Track Menu Settings you can change the duration of the BGM (Background Music)
Thank you so much for responding! Do you mean here shown in the attachment?
[Attachment 56382 - Click to enlarge] If that is where you meant, I think I changed that to a longer time frame but simulation didn't play but a few seconds and output didn't play the whole audio clip either.... -
Yes, that's the correct place to set it, and you appear to have done it correctly. Try setting your background to motion menu with background audio even if it's still.
TMPGEnc Authoring Works 5 Menu Help
By hurricane1951 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Feb 2022, 15:28 -
Creating more than fifteen chapters in a menu using Authoring Works 6?
By ibzomie in forum Authoring (DVD)Replies: 3Last Post: 2nd Aug 2020, 21:35 -
By ibzomie in forum Authoring (DVD)Replies: 1Last Post: 2nd Aug 2020, 16:01 -
Problem with TMPGEnc Authoring works 6
By pablur in forum Authoring (Blu-ray)Replies: 3Last Post: 9th May 2019, 06:49 -
TEMPGEnc Authoring Works 5 single menu DVD
By meridklt in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2016, 20:40
