Results 1 to 18 of 18
    May 2006
    Canada
    Hi. I'm trying to download this but each time it fails with either with Internet download manager and video downloadhelper.
    Can anybody please help me out ?
    PW: Blake123
    NB: VPN set to France
  2. IDM work fine.
    u have latest 6.38 b15 version?
  3. Get m3u8 url from a browser's Developer Tools (F12, network tab), then youtube-dl:
    youtube-dl "https://player.vimeo.com/external/485055936.m3u8?5c611816"
    Once you have the m3u8 URL you don't need a vpn or login.
    May 2006
    Canada
    IDM work fine.
    Strange. I do too. And each time I try, it says that the audio had to be downloaded separately. Then both files are out of sync in Adobe Premiere. Does it do the same thing to you ?
    Thanks to let me know
    May 2006
    Canada
    Tried that. Every time says this: Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
    I'm probably doing something wrong.
  6. It worked for me -- from USA with no VPN. I got a 995 MB mp4 file:
    [Attachment 56377 - Click to enlarge]
    I tried with a VPN set to Canada -- it worked there too.
    May 2006
    Canada
    Ok. I'll try re-installing my IDM and see if it's gonna work. Thanks
    May 2006
    Canada
    @lomero. Same results. It says after downloading that the audio had to be downloaded separately, but also the video files have problems with jump cuts, for some reasons. So, I really don't know anymore.
    @jagabo. It worked only once (without audio though) while I tried again with Video DownloadHelper. What browser did you use for downloading. I used both slimjet and Firefox. Thanks to let me know.
  9. Originally Posted by monks19 View Post
    I didn't use a browser to download the video. I only used FireFox to get the m3u8 URL. I used youtube-dl (a command line program) to download the video.
    https://youtube-dl.org/
    In all likelihood the m3u8 URL has changed by now. You will have to get a fresh one.
  10. i dont know. i dont have download the whole file all the way through. i just did a try and start with IDM...
    May 2006
    Canada
    How did you get the link, then ? I tried to get it and it didn't work (F12+Network) all I get are image segments (?) but no links.I must be missing something.
    [Attachment 56378 - Click to enlarge]
  12. Network tab
    ore use IDM to get m3u8 and after use this with yt-dl
    May 2006
    Canada
    UPDATE: Ok, I think I've managed to make it work. However, audio is missing and I don't know how to get it at all. Any ideas ? Also, the image does stutter a bit sometimes.
    Here are the indications of youtube-dl (see the attachment file. A lot of errors in there).
    So if anyone does have a solution, you're welcome.
    May 2006
    Canada
    Thanks. How did you manage to download it without any trouble ?
  15. Today the link I get with MS Edge browser is:
    With youtube-dl:
    youtube-dl https://player.vimeo.com/external/485055936.m3u8?5c611816
    Do you have a copy of ffmpeg.exe in your youtube-dl folder? That's needed to mux the video an audio together since youtube-dl downloads them separately.
    May 2006
    Canada
    With youtube-dl:
    Yes I do have the ffmpeg.exe in the folder. But for some reason, the link isn't displaying a vimeo video (on either Slimget and Firefox). Strange. One thing though, I'm using video download helper to get the link and also youtube-dl-gui. I've never been able to work with just Youtube-dl only.
  17. Weird. I thought I fixed the link in the last post. The forum software keeps mangling the url I got from Edge.
    https://player.vimeo.com/external/485055936.m3u8?X=5d00df6edbe76624e204aaa590245bcc5c611816
    Replace the X after the question mark with an s to get the true link. If I leave it as an s when I post the text is mangled to:
    By the way, youtube-dl shows the following streams are available:
    C:\Youtube-dl>youtube-dl -F "https://player.vimeo.com/external/485055936.m3u8?5c611816"
    [generic] 485055936: Requesting header
    [redirect] Following redirect to https://141vod-adaptive.akamaized.net/exp=1608799293~acl=%2Fd1958970-0188-48f7-b3fe-3b5c6c7f8334%2F%2A~hmac=e058c9d26bbb513aec5e0385130a950e0f59fcb881c00d1c88c2c8ee7d7b7ca0/d1958970-0188-48f7-b3fe-3b5c6c7f8334/sep/video/f101eeb7,74536351,56637756,3be5c7f2/master.m3u8?absolute=1
    [generic] master: Requesting header
    [generic] master: Downloading m3u8 information
    [info] Available formats for master:
    format code         extension  resolution note
    audio-high-audio    mp4        audio only
    audio-medium-audio  mp4        audio only
    391                 mp4        426x240     391k , avc1.640015, 25.0fps, video only
    564                 mp4        640x360     564k , avc1.64001E, 25.0fps, video only
    1399                mp4        960x540    1399k , avc1.64001F, 25.0fps, video only
    2590                mp4        1280x720   2590k , avc1.640020, 25.0fps, video only (best)
