Results 1 to 16 of 16
    Aug 2018
    Ghana, West Africa
    I'm watching a video in virtualdub that is 14:26 minutes long, however, VirtualDub stops at frame 14001, which is 07:50 minutes long. I'm trying to find a way to increase the limit , but haven't found anything that even remotely hints doing so yet.
    Update: Tried another video that was 09:24 minutes long, and the frames stop at 16700, which is 09:17:223 minutes long. .....I am SO confused right now, and it would mean a lot if someone could help me solve this.
  2. Variable frame rate sources?
    Aug 2018
    Ghana, West Africa
    The framerate is the same for both videos
  4. what does mediainfo (view=>text) say about the files ? copy/paste the text back here
    Did you try vdub2 ?
    Aug 2018
    Ghana, West Africa
    Whoops, this is virtualdub2. All this time, I've been calling it just virtualdub. I don't have any dropdown options that say text
    Aug 2018
    Ghana, West Africa
    General
    Complete name : C:\Users\david\Downloads\SFM Related\Pose Reference\Sit to Stand\How to animate a character sitting and standing Part 2.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 53.2 MiB
    Duration : 14 min 26 s
    Overall bit rate : 515 kb/s
    Writing application : Lavf56.40.101
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 3 frames
    Codec ID : avc1
    Duration : 7 min 50 s
    Duration_FirstFrame : -33 ms
    Bit rate : 766 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 29.970 (29970/1000) FPS
    Minimum frame rate : 29.970 FPS
    Maximum frame rate : 29.990 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.028
    Stream size : 42.9 MiB (81%)
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 93.6 kb/s
    Channel(s) : 1 channel
    Channel layout : C
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 9.67 MiB (18%)
    Default : Yes
    Alternate group : 1
  7. Duration : 7 min 50 s
    It reports the video stream duration as 7 min 50 s, audio as 14min 26s
    Does it play and seek ok in a media player ? eg. mpchc, vlc ?
    You probably have to convert it to constant frame rate
  8. I'm a Super Moderator johns0's Avatar
    canada
    Run it through tsmuxer and check change fps to 29.97(30000/1001),if it muxes with no issues then it was a regular 29.97 file encoded as variable.
  9. Also after loading into VirtualDub2 check whether the last frames you can see come from the middle of the video or the end of the video (as played in a media player).
    Aug 2018
    Ghana, West Africa
    Oh wow, it stops at that same spot on VLC as well. How do I change it to constant frame rate?
  11. Does it keep on playing the audio? or stop everything ?
    I doubt it's a variable frame rate issue if VLC stops at 7min 50 , and everything before that seeks and plays ok
    Check another player like MPCHC - if it behaves the same way, you might be missing some video stream
  12. I'm a Super Moderator johns0's Avatar
    canada
    Did you read what i posted about changing it to constant frame rate?
  13. Originally Posted by poisondeathray View Post
    And are the audio and video in sync when you play it? Does the end of the video (as played) correspond to what you expect at the end of a video -- closing credits maybe? Or does it just seem to cut out at some random spot?
  14. Just download it again
    I'm guessing it's this video
    youtube-dl -f 136+140 https://www.youtube.com/watch?v=pPu2MZTu7vw
    This is 25980 frames in vdub2
    File size                                : 85.7 MiB
    Overall bit rate                         : 830 kb/s
    Writing application                      : Lavf58.65.100
    Video
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 728 kb/s
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.026
    Stream size                              : 75.2 MiB (88%)
    Audio
    Format                                   : AAC LC
    Channel layout                           : C
    Stream size                              : 9.67 MiB (11%)
    Default                                  : Yes
    Alternate group                          : 1
  15. So... it two different videos, both from YouTube, exhibit the same issue, whatever method was used to download them might be malfunctioning.
    I've seen once a YouTube video which could be downloaded fine with “-f 136+140” yet the “-f 22” version was somehow truncated ; but this doesn't seem to be the case here, and the specifications wouldn't match as the audio is identified as “192k” for the “22” version.
    (Can't find which video it was, but here is one for which the “22” stream has corrupted audio while the “140” M4A audio is fine.)
