I'm looking for a solution to capture screenshots from ST.2084/REC.2020 encoded 4K-UHD blu-ray discs.
I know Xbox will let you capture into the .JXR-format, but I don't have Xbox.
Also, I don't have any 3840x2160 HDR display connected to my PC, I'm on a 1080p 8-bit SDR NTSC 45% laptop.
I know madVR converts to SDR automatically, MPC-HC's EVR renderer will only capture 8-bit.
Is there any free software that's able to capture 10-bit, 3840x2160, ST.2084/REC.2020 screenshots?
FFMPEG?
The screenshots will be used for HDR Heatmap + WCG Analysis.
Thank you, first time poster!
I found a freeware, see below:
https://www.videohelp.com/software/LosslessCut
Captures with a 16-bit gamma integer if you select to save screenshots in .PNG-format.
Captures the complete 3840x2160 resolution, no need for a 3840x2160 monitor/display.
Works with both .MP4/.MKV.
Used FFMPEG to switch container from .MP4/.MKV - no issues.
Cheers!
Convert rec.601 into rec.709?
By killerteengohan in forum RestorationReplies: 8Last Post: 15th Jun 2021, 19:25 -
Converting rec.709 to rec.601?
By killerteengohan in forum RestorationReplies: 22Last Post: 13th Jun 2020, 17:19 -
10bit BT.2020 HDR content to 10Bit BT.2020 WITHOUT HDR metadata
By wmplib in forum Video ConversionReplies: 3Last Post: 10th Apr 2020, 08:44 -
MKV-Bluray Screenshot Software
By BoneCrusher in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2020, 07:30 -
can x264vfw do change rec.601 --> rec.709?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2017, 16:06
