    Jun 2008
    When I watch disney's onward with VLC player, every few minutes the video would pause for a few seconds while the audio continues. I checked the dvd and see no scratches or obvious defects.
    What is the next best software dvd player for win10 that does not use the same component as VLC player (e.g. ffmpeg)?
  2. Member stax76's Avatar
    Nov 2009
    On thin ice
    All players in the end are ffmpeg based. You can try to enable/disable hardware decoding.
    Alternative players are MPC-BE and mpv.net.
  3. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Why are you assuming it is VLC?
    Rip the Video and try to play it. If it plays fine once ripped then it is either the disc, the hardware player, or both. If it still doesn't play once ripped then it could be VLC or your PC (or some combination).
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    Jun 2008
    I subsequently play the DVD with windows DVD player on the same PC and it plays fine no stutters.
    Unfortunately I returned the DVD to the library so I cannot experiment anymore, unless run into this again in the future. I still use VLC as my default player.
