I have been converting my DVD series to mkv/mp4 for years and the file sizes have always bothered me. I just upgraded to the newest version of Handbrake and every preset seems to give insane file sizes. I'm ripping a series with 45 minute episodes right now and they are coming in at over a gig apiece. As a test I ran the 30 second preview under a ton of different presets and they were all between 7 and 9mb for a 30 second clip. That's roughly 600 to 800mb each episode. I thought .x265 was supposed to have substantially lower filesizes but it was in the same range. Can some seasoned vet tell me if I'm just expecting for the impossible here? Is it really not possible to have 300-400mb episode sizes? It's an old SD TV series from the 80s. I'm hoping not to have to encode 10 hours an episode or anything, but even when I chose "Very Slow" encoding the file size didn't drop (and the quality didn't get appreciably better).
Thanks!
I had previously ripped the DVDs to my HDD. I pointed clever FFmpeg at the VOB and it made a new VOB of the whole episode (took several minutes), however at the end it threw a bunch of errors. I quit out and tried the x86 version just in case, same issue. Continued past the errors and it says "Analyzing video" but it's clear the errors stopped that from actually occurring. Here is the error text:
Code:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo) at System.Diagnostics.Process.Start() at clever_FFmpeg_GUI.Module1.ShowVideoTracks() at clever_FFmpeg_GUI.Form2.Show_Tracks() at clever_FFmpeg_GUI.Form2.Button2_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- clever FFmpeg GUI Assembly Version: 1.0.0.0 Win32 Version: 2.6.9 CodeBase: file:///C:/Temp/cleverffmpeg/x86/clever%20FFmpeg%20GUI.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 14.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 4.0.0.0 Win32 Version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. -
Sorry, downloaded the beta/nightly and still getting errors. I deleted the .vob the earlier version made of the whole episode and the new version created it again, then errored out at the same point as last time.
Anything I can do to help you troubleshoot? Should this move to a different forum location? -
Handbrake used to have a setting for desired file size, I used it all the time. After they removed it, I started using https://vidcoder.net/, just because it kept that feature while using the Handbrake encoder.
Import your file, select the gear at the end of the file name>Video Encoding Tab, set Quality to Target Size and insert the value you want. -
Remux the vob first with mkvtoolnix to mkv and load the mkv into clever ffmpeg-gui
But it's better, generally speaking, to have a set quality setting rather than a set size setting, as different contents can have vastly different bitrate requirements for the same perceived quality preservation. Target file size should be used only when there's a specific requirement, like fitting X files on a DVD. With x264, CRF = 23 as suggested above seems about right to get a significant size shrinking with a decent quality preservation ; beyond that, quality will start to dwindle pretty fast ; unless O.P. is satisfied with the likes of Y*FY releases, then it can be increased to CRF = 27 or moar...Handbrake used to have a setting for desired file size, I used it all the time. After they removed it, I started using https://vidcoder.net/, just because it kept that feature while using the Handbrake encoder.
Don't know how these numbers translate with x265. All I can say is that I've watched a few movies encoded in 1280xsomething (which is stupidly called “720p” even if the height is cropped way below that) in x265 at low bitrate and while the quality was generally decent, they exhibited ugly motion artifacts, the kind of which I've never seen with low bitrate x264 encodes. In particular, hardcoded subtitles over a moving background result in an atrocious mess. (In this case the movie is Rush, about the 1976 Formula 1 championship, so there's a lot of motion, duration is 2h02m and it's in 59.94 FPS which probably doesn't help to get it all crammed down to 823MB, or 767MB for the video stream, or 874kbps. According to MediaInfo it was encoded with crf=26. I notice just now that audio is OGG Vorbis at only 64kbps, yet I wasn't bothered by the audio quality.)
Handbrake locks my .ass file
By dimailer in forum SubtitleReplies: 1Last Post: 3rd May 2020, 13:29 -
file size versus video size
By liquid xtal in forum Newbie / General discussionsReplies: 8Last Post: 15th Apr 2020, 07:38 -
Handbrake stopped reducing file size
By hpcampr in forum Newbie / General discussionsReplies: 9Last Post: 2nd May 2018, 10:32 -
DVD's PAR and output display size explanation in Handbrake
By Superfrank in forum Video ConversionReplies: 3Last Post: 11th Feb 2017, 17:27 -
Subtitle Size in Vicoder and Handbrake
By mhhack in forum SubtitleReplies: 1Last Post: 1st Jan 2017, 07:57
