Results 1 to 14 of 14
    Sep 2010
    Argentina
    Hi guys first excuse me if this thread is in the wrong section, I dont know where?
    I wish to find this desktop icons
    https://1.bp.blogspot.com/-MqRRXdOHaJg/XoO6op9rDUI/AAAAAAAAKYU/W7iRc4yzJXUfphvcIIw-k72...elta%2BFuc.png
    As You can see in the picture thereīs recycle bin, This PC and users file, are in my first language, anyway the recycle bin turns in that color when is full and turns in another color when turns empty I just dont know where can I find this icons?
    Thank You very much in advance
  2. Member Cornucopia's Avatar
    Why don't you just create them?
  3. DECEASED
    Jun 2009
    Heaven
    Maybe in a Windows 10 forum?
    EDIT:
    attaching the image to this thread, just in case...
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Sep 2010
    Argentina
    How can I do that? I mean is easy? I need to draw? or just select objets?
    Sep 2010
    Argentina
    EDIT:
    Thank You very much
    Sep 2010
    Argentina
    Yes I so that I installed that but I wish to backup in some way those icons from that Windows Delta and can restore that icons in another Windows, is there some tool or way?
    Sep 2010
    Argentina
    Thank You again I already tried that but in default mode donīt find nothing
    Sep 2010
    Argentina
    Thank You I find de DLL file that contains the icons I tried reemplace it with the DLL Windows default but Windows donīt let me do it, I donīt know if I jhave to replace this DLL that contains the icons or I need to save this Icons on a ICO file this is the thing I donīt know how to do it
    Iīll so appreciate if you can guide me?
  9. I think you have to replace the dll. It must be from the same Windows version you use. I think it can be replaced offline only, so you have to boot your system with a winpe g.e.
    Sep 2010
    Argentina
    Thank You for that, I select from Windows the DLL from another location and replace it but not booting method I will try that you say
  11. Member Cornucopia's Avatar
    You SHOULD NOT replace any standard Windows DLL merely for purposes of using the icons within. That can corrupt & destabilize the system.
    Windows and other apps can make use of various DLLs, it just needs to be pointed to them.
    For example,
    # Create a Shortcut with Windows PowerShell
    $TargetFile = "%windir%\System32\shutdown.exe"
    $argA = "/l"
    $argB = "/f"
    $ShortcutFile = "$env:Public\Desktop\Log Out.lnk"
    $WScriptShell = New-Object -ComObject WScript.Shell
    $Shortcut = $WScriptShell.CreateShortcut($ShortcutFile)
    $Shortcut.TargetPath = $TargetFile
    $Shortcut.WorkingDirectory = "%windir%\System32"
    $Shortcut.Description = "Log Out"
    $Shortcut.IconLocation = "shell32.dll,176"
    $Shortcut.Arguments = $argA + " " + $argB
    $Shortcut.Save()
    This uses PowerShell to create a shortcut on every users' desktop (notice it is in "Public", so common to all). It is for a more straightforward (for those still stuck in earlier Windows eras or Mac->Win converts who don't know how to use the Start button items) and simplistic way to logout. Notice, it uses the stock Windows "shell32.dll" system API file as its source for icon resources. Also notice: it shows icon position "176", so is the 177th icon resource available - numbering starts from 0.
    This code could easily be changed to point to any other ICO or DLL that has icon resources, in any other path (this one was Windows/System32, but could be anywhere), and any other number order.
    Seriously, you could have created and drawn the icons yourself by now. They aren't that hard. Here's a Question Mark I did about 5 years ago: Image
    [Attachment 56330 - Click to enlarge]
    , and I have an icon that I created over 20 years ago which was the source of my animated GIF avatar (Groucho).
    And there's plenty of web topics that explain how to access & take advantage of icon resources in the various resource files (EXE, ICO, DLL, etc). You can start by taking a look at IconViewer, so you can see which resources have which icons.
  12. DECEASED
    Jun 2009
    Heaven
    Scott is right, it's totally unnecessary to replace a system DLL if the only goal is getting some icons for the desktop shortcuts.
    You can extract only the icons you want/need from a DLL or an EXE, any decent free icon editor can do that.
