Results 1 to 9 of 9
  1. What i did wrong ?
    Could not recognize filter settings for 'HB_FILTER_NLMEANS' with preset '', tune '' and custom settings 'y-strength=6:y-origin-tune=1:y-patch-size=7:y-range=3:y-frame-count=2:y-prefilter=0'
  2. This settings work in handbrake but in vidcoder didn't . I can't figure out why .
    Could not recognize filter settings for 'HB_FILTER_NLMEANS' with preset '', tune '' and custom settings 'y-strength=1.5:y-origin-tune=1:y-patch-size=4:y-range=3:y-frame-count=2:y-prefilter=0'
  3. After many tests , i found it's work with version 3.16 with handbrake core 1.12 , the last version 5.21 don't work ... i don't know why.
    Mar 2008
    Have you tried the latest Vidcoder 6 beta ?
    https://www.videohelp.com/software/VidCoder
    I've been using these beta releases, they work pretty well
  5. Thank you , i will try.
  6. I tried 6 beta version but nlmeans custom settings give same error.
    Mar 2008
    Yes the format of the command string has changed. For example, for preset "light" you get:
    (y-strength=3:y-origin-tune=1:y-patch-size=7:y-range=3:y-frame-count=2:y-prefilter=0:cb-strength=3:cb-origin-tune=1:
    cb-patch-size=7:cb-range=3:cb-frame-count=2:cb-prefilter=0)
  8. Anonymous
    Guest
    All versions work for me except version 5.21, which does not work
    Mar 2008
    I see this in the log for the latest 6.x beta, same as reported by the OP earlier
    "Could not recognize filter settings for 'HB_FILTER_NLMEANS' with preset '', tune '' and custom settings 'y-strength=1.5:y-origin-tune=1:y-patch-size=4
    :y-range=3:y-frame-count=2:y-prefilter=0 "
