Every 5th frame is interlaced. How do I address this in avisynth? I've attached a sample of the video you can download below.
https://www.dropbox.com/s/cvrrmuayf7wr6xa/every%205th.mkv?dl=0
You should provide a panning shot. I suspect you'll find more interlaced frames.
You're probably going to want to field match followed by decimation -
That would be interesting if it was really every 5th.
I'd be curious to see such a script, just because.
I have a video where interlace reverses itself (not TFF then BFF, but TFF where the field invert; bottom is over top, but still TFF without judder). It comes and goes, so needs a specified frames start/end.
This would need some sort of auto to specify 5th. The issues are related, weird interlace damage.Want my help? Ask here! (not via PM!)
In the OP's case it may simply be because his sample clip is all 12p character animation. That naturally leads to 1 interlaced frame out of every 5 frames when telecined to 29.97i.
Regarding your video which switches between scan lines in the correct order (0,1,2,3,4,5...) and scanlines in the wrong order (1,0,3,2,5,4...) you can probably create two videos, one with just TFM(), the other with SwapFields().TFM(), then use a runtime filter to select the frame with the least aliasing. If you provide a sample I'll take a stab at it...Last edited by jagabo; 15th Dec 2020 at 13:38.
There aren't any panning shots but below is a zoom shot. What would be the best way to go about field matching and decimation?
https://www.dropbox.com/s/48j9e6p1dideld4/every%205th%20-%202.mkv?dl=0 -
It's standard 3:2 pulldown. A Simple TFM().TDecimate() will restore the original 23.976 film frames.
Code:LWLibavVideoSource("every 5th - 2.mkv", cache=false, prefer_hw=2) TFM() TDecimate(mode=1) # mode 1 might be a little smoother than the default (0)
Partial frame stab() as basis for whole frame? (Avisynth)
By lordsmurf in forum RestorationReplies: 28Last Post: 11th Sep 2020, 10:36 -
Frame-by-frame combing detection in AviSynth
By ZetaStax in forum Video ConversionReplies: 3Last Post: 2nd Sep 2019, 15:43 -
Audio gets out of sync when "decimating" on 6th frame instead of 5th
By jaibubwan in forum EditingReplies: 31Last Post: 12th Apr 2018, 12:45 -
[AviSynth Help] Fixing interlaced frames in an anime video.
By SUP3RDeathStar in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2017, 18:39 -
Every 5th frame is a repeat
By pooksahib in forum Video ConversionReplies: 12Last Post: 4th Dec 2017, 00:24
