I am considering upgrading MMC 7.1 to 7.6.
I`m just a bit concerned as i heard that the MMC 7.2 and above were designed for the Radeon Chipset.
The ATI site still has 7.1 as the official download for my card.
Anyone tried the AIW 128 Pro with 7.2 or above ?? does it work properly ?
If it does, does 7.6 split MPEG2 captures to get round the 4gig limit in Win 98SE ? or is it just AVI caps it can split ?
Where can i get hold of 7.6 ?
Hope someone can help !
Cheesemeister2000
Do the upgrade, it works great.
MMC 7.6 works great for me with the AIW pro 32 meg card. I've tested it in 98se, win2k and winxp without a problem. You should see a significant increase in quality in real time mpeg2 captures after the upgrade. I personally feel that ATI discourages the move to MMC 7.6 with an AIW pro 32 because they would prefer you to upgrade your card to a Radeon (+$). Give it a try, it should work fine as it has for me.
My advice is as follows:
1. Install MMC 7.6
2. If the TV icon does not appear or gives you problems then search this board using my screen name "next' and install the dll's I have suggested in previous posts.
3. I have found that cbr captures at 2.51mps or 2.57mps will give excellent quality. I'm not a fan of vbr captures under MMC 7.x because you cannot set a minimum or maximun mps. With 2.51 or 2.57 cbr you should get close to 40 minutes on an 800 meg cdr.
4. Run your captures through Mpeg2vcr to gain SVCD compliancy. It only takes a few minutes.
5. Cut and edit to fit the cdr of your choice (Mpeg2vcr). Burn your SVCD in the burning program of your choice. I use Nero. It works.
6. Optional - get a multi tray DVD player. Saves the hassle associated with changing a disk.
I have noticed that MMC 7.6 is so good that I have a hard time telling the difference between a MMC 7.6 capture and a DVD rip. At least as it relates to a casual observer (I can see a difference but most viewers cannot). As a matter of fact I watched a movie recently and was convinced it was a rip and was suprised ( way surpised) that it was a capture. Had no idea while viewing (32 inch TV).
For those of you who gave up on ATI give it a try - amazed here.
But source matters ....make sure it is clean. -
Just reread the thread - I was focussing my comments on Mpeg2 and SVCD captures. Sorry if that was not clear.
Also - get Stinky's tool! And check out the credits. Thanks Stinky - I've been way too busy to help. You are a gentleman and a scholar - great work!
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24
