  1. Hello,
    I have an issue with converting my videos
    Generally the videos are just audio files with added visualization, the video i make is in 1080p at 25 Fps
    I have enabled hardware acceleration with my nvidia gtx 1060 however i don't see any fps increase on conversion
    additionally i have checked task manager it shows 0 % GPU usage on conversion and pc usage is 42 %
    i am getting only 40 fps and after a minutes it drops to 6 fps, how can i fix this ? or is this normal
    i have tried different video codecs with no change in fps , at this ratio a 30 min video takes over 2 hours to export :-I
    thank you in advance
    i5-7600 k
    gtx 1060
    16 gb ram
    256 ssd
    Aug 2013
    Central Germany
    If you want to use the NVEnc hardware encoder, I guess you should also check "Use hardware acceleration for encoding video". If not, I guess it might only be used for some filtering, but the encoder is still software? (I don't know what "VSDC" is.)
